trans. gear swap. read.
Old Mar 25, 2005 | 02:57 PM
junbb1's Avatar
Default trans. gear swap. read.
i am curious to see if anyone has put a fifth gen 3.285 first gear into a fourth gen trans. which has a 3.307. i know it will fit the countershaft because the specs are the same for both models. i was just curious if anyone had done this.
please only infomative responses. dont post any- well why would you do that questions.
if anyone has then i wil answer questions.
Old Mar 25, 2005 | 03:45 PM
flyrod's Avatar
Default Re: trans. gear swap. read. (junbb1)
Some people have reported success with this, but I have been through the guts of several H-series trannies trying to put a taller 5th into a M2F4 and have not found swappable gears. The 5th gen may work, I have not seen inside one of those. Corey (honda318?) has done it I think, but I never got the details. If someone knows for sure which gears can be swapped, please post some details!
Old Mar 25, 2005 | 04:22 PM
junbb1's Avatar
Default Re: trans. gear swap. read. (flyrod)
4th and 5th gen counter shafts are the same part number. main shafts are different though. this is one of my concerns.
Old Mar 26, 2005 | 12:14 PM
junbb1's Avatar
well it wont work. tried today. i could have probably used the 5th gen mainshaft and swapped the 4thgen 3rd, 4th, and 5th gears over. i would have had to use the fifth gen 1-2 gears. i would have done this but i just replaced my synchro slider assembly a year ago and the set out of the 5th gen was beat up. i would have had to buy tha different 1-2 synchro set to fit the 5th gen gears, and i did not wont to spend the money. so maybe another time.
bennyBronco
Sep 8, 2011 09:06 AM
OaklandAlive
Oct 11, 2005 12:16 PM
JDM H23A
Oct 5, 2005 05:25 AM
Panda-san
Jun 2, 2004 07:41 PM
Vexamus
Oct 2, 2002 02:48 AM
