I'm having trouble..Skunk2 Manifold
Where does hose lead to in the pic. I know in the pic it leads next to the TB but
that already has a hose in in leading somewhere else which I never touched.
So I'm kinda lost.
So I'm kinda lost.
if i remember correctly, the skunk2 only has that one coolant tube and it spits into a Y. ahh just PM me ill take some pics for you, alot easier than trying to explain
i just took some pics for you, i hope this helps...
this is the ONE coolant passage comming from the intake manifold. as you can see it goes to the thermostat.
as you can see there is another coolant passage comming off the main big daddy one that goes to the thermostat. plug that one up
now your going to need to feed your throttle body with coolant, to feed mine i ran a hose from under the vtec solenoid to the passage on the throttle body, heres a pic of the passage under the vtec solenoid.
and a pic of the line going into the throttle body
it was hard to get pics of the next steps, but ill just explain. there is an "exit" on the other side of the throttle body, that runs into the bottom of the IAC valve, then there is an exit on the underside of the IACV then will run into the main coolant passage behind the block. its that big tube that runs under the intake manifold and is on the block. just think of the coolant as one big flowing curciut, which is what it is. i hope this helped
Adam
Adam
1337 Si
Mar 24, 2005 09:26 AM
