engine build-up q's
Old Jan 25, 2002 | 02:37 PM
AudioXtremes's Avatar
Default engine build-up q's
I'm gonna be running a d16a6 block with a z6 head. with such high compression(10.4 to 1 supposably) i wanna build up the bottem end a little bit for nitrous(about a 75 shot maybe 100) with just some new rods and forged pistons. i can get eagle rods for 300. are these ok rods and is that a good price. i have no idea where to get pistons and what good prices are, so any help would be appreciated. remember that i dont the BEST stuff. just good stuff for the money. i understand you get what you pay for. also is a 88-89 teg ecu ok to use for the higher rev limit??? thanks.
oh and if your going to say "just do a engine swap" DON'T!!!!!
I am building a d series for the purpose of BUILDING A D SERIES!
[Modified by AudioXtremes, 11:41 PM 1/25/2002]
Old Jan 25, 2002 | 04:05 PM
ihaterice's Avatar
Default Re: engine build-up q's (AudioXtremes)
mad props for building a d series..these little engines are actually pretty damn good...as far as eagle rods, i would use them, any aftermarket rods are going to be just fine for what you are looking to do with them (a 75 shot of NOS really isn't a whole lot in the whole scheme of things) so just look for the best deal on aftermarket rods and they will hold up just fine for what you want to do with them...as far as pistons go, i would take the same advice, shop around and see what is out there...reliability issues shouldn't concern you that much with any of the aftermarket rods or pistons out there for your application (it is not like you are shooting for 400 hp)...if you wanted to do a little budget build..i know for sure that integra ls rods can be made to fit into d16z6 blocks, not sure about d16a6 blocks but those rods are good up about 225 hp or so comfortably and then there is always a b series throttle body that can be bolted on (those can be had for $50-75) and one last suggestion for you, definately try and get a obd0-obd1 conversion harness so that you can use a 92-95 sohc vtec (p28) ecu with that setup..it will definately let the engine run 100 times better
Old Jan 25, 2002 | 04:19 PM
Default Re: engine build-up q's (ihaterice)
thanks man. does anyone know where the cheapest places to buy are?? i do searches and all i find are for domestic. thanks.
Old Jan 25, 2002 | 05:34 PM
afstlsvtec's Avatar
you can use ls rods, i was going to go fully built sohc vtec turbo and i was going to use ls rods with aris pistons,,,
Old Jan 25, 2002 | 05:36 PM
Default Re: engine build-up q's (afstlsvtec)
where can i get aris pistons cheap?
Old Jan 25, 2002 | 05:47 PM
afstlsvtec's Avatar
go to http://www.thepartstrader.com or look around on sites like that or recycler
Old Jan 25, 2002 | 10:15 PM
bryant's Avatar
check out: http://www.theoldone.com i think that is the site.
Old Jan 26, 2002 | 08:42 PM
Default Re: engine build-up q's (CR-X)
do i need different rod pins or anythingto run some ls rods??g
Old Jan 26, 2002 | 10:13 PM
MrFatBooty's Avatar
http://www.raceeng.com
They should have pretty much anything you need.
Old Jan 27, 2002 | 10:16 AM
Default Re: engine build-up q's (MrFatBooty)
that site is very informative. thanks. has anyone here ever built a d series before? and what are your results.
Old Jan 27, 2002 | 10:24 AM
SiR Kid's Avatar
New User
WOW. Some of you people amaze me.
First off, they're ARIAS pistons. Summit Racing carries them for imports.
I'd strongly suggest to go ahead and get some eagle rods <$300 is a GREAT price> and a set of JE, Ross, Arias, or Wiseco pistons. Wiseco being the most expensive of the bunch. I'd buy new pistons. I got screwed on a set of JE's that had gotten hot and gone oval. No way to bore an oval cylinder, y'see?
Parts trader is great for bolt ons, but internals, I'd buy new, personally.
Old Jan 27, 2002 | 01:04 PM
Default Re: engine build-up q's (SiR Kid)
I'm gonna go with eagle rods. but how are srp pistons??
Old Jan 27, 2002 | 01:17 PM
SiR Kid's Avatar
New User
SRP's are a cheapo racer version of JE's... save your pennies and buy the je's if you go that route.
Old Jan 27, 2002 | 01:26 PM
ok well with a built bottem end with about 11 to 1 comp on a 100 shot. i will need a metal head gasket right? and you have to O ring your head right???
[Modified by AudioXtremes, 10:27 PM 1/27/2002]
Old Jan 27, 2002 | 07:32 PM
anybody?
Old Jan 28, 2002 | 03:28 PM
SiR Kid's Avatar
New User
No.
Run a stock headgasket. I'd rather blow a headgasket than a piston or valve, how about you?
it should hold up fine with 11:1 and 100 shot as long as it's TUNED.
Old Jan 28, 2002 | 05:12 PM
oh it will be tuned on a dyno. i guess a stock gasket will be what i use then. just seems kinda weird.
Old Jan 29, 2002 | 03:08 PM
TheShocker's Avatar
Good man!
Stanceman
Jan 12, 2021 04:19 AM
bigsnorlax
Mar 22, 2010 09:48 AM
SIred91
10
May 13, 2006 09:30 AM
idewson
Jan 4, 2006 10:38 AM
gsr camel
Oct 8, 2001 12:43 AM
