car wont start after swap
Old Mar 25, 2005 | 02:06 PM
silver hatch's Avatar
Default car wont start after swap
i swapped a zc into my 1991 civic. and now it wont start. it wont even turnover, the starter doesnt engage at all. when i first put the key in a turn it one click,the dash lights( check engine, oil pressure,etc) come one then go out( like they should). they when you turn the key the rest of the way as if you were gonna start it nothing happens(i can hear the main relay click). i can also hear the fuel pump running fine. also, when you have the key turned as if it you were goin to start it i can hear the fuel injectors running. does anyone have any ideas as what could be the prob.?? could it be a problem with mpfi wiring? at first i thought maybe clutch wasnt engaging all the way, but that doesnt seem to be the case. both wires are hooked to the starter.
Old Mar 25, 2005 | 02:16 PM
91Notch5.0's Avatar
Default Re: car wont start after swap (silver hatch)
If all your wires and grounds are good then it could be bad battery..had the same problem about 20 min.s ago lol
Old Mar 25, 2005 | 02:46 PM
Default Re: car wont start after swap (DSM2GNT95)
no its not the battery. i charged it because it was sittin for a few months, tried boosting it and tried a battery out of another running car.
Old Mar 25, 2005 | 03:19 PM
bob06's Avatar
when you get in the car and turn the key to the ON position do you hear a lot of clicking coming fro the relays and a lot of clicking coming from the injectors? If so then you probably forgot to hook up your ECU ground. I had the same problem. It sometimes falls down underneath where you can't see it. It will be on the left side when you are facing the engine on the backside. It is just a little wire that bolts to the thermostat housing.
Old Mar 25, 2005 | 07:57 PM
Default Re: car wont start after swap (bob06)
thats sound like it could be the problem. ill try it. because i do hear some clicking.
is the ecu ground on the wire harness?
Old Mar 25, 2005 | 08:02 PM
jlicrx's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silver hatch &raquo;</TD></TR><TR><TD CLASS="quote">
is the ecu ground on the wire harness?</TD></TR></TABLE>
yes, ECU ground is on the engine harness - usually that doesn't keep it from turning over - just won't start - is the starter good?
Old Mar 26, 2005 | 07:16 AM
Default Re: car wont start after swap (jlicrx)
im not sure, is there some way to check it? can i wire it direct to battery or something?
Old Mar 26, 2005 | 10:45 AM
doublethink's Avatar
ground at the thermostat housing, ground to the valve cover, ground from the battery to the chassis.
if you mpfi wiring is fucked, the car would still at least crank, just not turn and throw codes, check your grounds first.
use a helms manual:
http://tech.hybridgarage.com/t...l.pdf
good luck.
Old Mar 26, 2005 | 11:01 AM
Default Re: car wont start after swap (doublethink)
it turns out that it was the ground to the thermostat
Old Mar 26, 2005 | 11:19 AM
CRseXxy's Avatar
i was gonna put my money on a ground wire. My jeep did that and i replaced both battery terminals and the starter. Turned out, oil gunked up on one of the grounds. cleaned it and that was it. but in the future, unbolt ur starter but leave it hooked up. The starter will spin if it works, but in my situation the starter didnt spin because of the bad ground. well whatever did it start?
Old Mar 26, 2005 | 02:10 PM
Default Re: car wont start after swap (CRseXxy)
yeah it started. i was surprised it started, the gas has been in there for about 3 months with no stabilizer. i started it without exhaust hooked up and it was loud. it was comming right out of the manifold.
Old Mar 27, 2005 | 08:58 PM
TurbourSedan's Avatar
make sure all of you wiring is ok, check the distributor, see if its getting spark
Old Mar 27, 2005 | 09:28 PM
31flavorscivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silver hatch &raquo;</TD></TR><TR><TD CLASS="quote">yeah it started. i was surprised it started, the gas has been in there for about 3 months with no stabilizer. i started it without exhaust hooked up and it was loud. it was comming right out of the manifold.</TD></TR></TABLE>
Hahaha. Exactly my thing. DOHC ZC no start, and we were so excited to see it run that we fixed it and tried to start it before the exhaust was hooked up and got a few disturbing the peace complaints at 11.00 at night. VERY loud. We also went to a friends house open header and wore earmuffs because it hurt bad.
Nothin like that first time startin
Old Mar 27, 2005 | 09:34 PM
Jay.D.Em!'s Avatar
dude it could be your timing, i tried the same thing in my 89 hatch and th etiming was off by ****** 6o degrees.. after i fixed it it started right the **** up..i had the SAME EXACT PROBLEM!!
Old Mar 29, 2005 | 05:08 PM
CRseXxy's Avatar
Default Re: car wont start after swap (CR_Xtasy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CR_Xtasy &raquo;</TD></TR><TR><TD CLASS="quote">dude it could be your timing, i tried the same thing in my 89 hatch and th etiming was off by ****** 6o degrees.. after i fixed it it started right the **** up..i had the SAME EXACT PROBLEM!!</TD></TR></TABLE>
he just said it was his ground wire
s1ngle
10
Aug 19, 2011 06:13 AM
G2integra217
Jan 30, 2007 09:14 AM
cbstudd77
Dec 20, 2006 07:40 PM
fanatic
Nov 5, 2005 06:00 PM
technine
Oct 24, 2002 03:50 PM
