Suspension & Brakes Theory, alignment, spring rates....
ground control ordering?
Old Mar 25, 2005 | 01:33 PM
crxgator's Avatar
Default ground control ordering?
within the next month i want to order groun controls and koni yellows for my crx...i went onto ground control's website because i heard you can swap out springs...i only found that available for 92-00 civics, while the 88-91 civic/crx only had the "limited edition"...
i want to make sure, that the 92-00 will work on my crx...i called up ground control, but i dont think the guy understood what i was talking about...can i also try and order this setup from a "local race shop" or does changing the spring rates, mean i have to order from them directly...
im looking to get these in a 400/450 rate...apparently this is a race only kit...how much "damage" could i cause if i ran it on the street? premature wear? any help would be appreciated...
Old Mar 26, 2005 | 03:51 AM
Targa250R's Avatar
be professional
Default Re: ground control ordering? (crxgator)
Err, forget what the web site says. Just call up GC and ask for a set of their coilover sleeves with 400f/450r spring rates, to be used with Koni dampers on an '88-91 CRX.
You're not going to damage anything by driving it on the street unless you constantly hit large potholes/curbs/etc. at high speed and bottom out the dampers internally.
blackstar
Apr 10, 2013 10:55 PM
droogie
Suspension & Brakes
Dec 3, 2011 06:52 AM
fergs96integra
Suspension & Brakes
18
May 24, 2006 07:02 PM
atc5
Suspension & Brakes
Nov 23, 2005 07:06 AM
InTegraLS_2001
May 4, 2004 04:27 PM
