Code 22 Weird Problem (searched)
Old Mar 25, 2005 | 01:09 PM
Prod's Avatar
Default Code 22 Weird Problem (searched)
I'm curious if anyone has had a similar problem, I occasionally throw a CE for code 22 but only when I go WOT into 4th gear, 1 second into 4th gear the light goes on...otherwise the car runs great. I checked all my grounds and connections everything looks good as it should since the car runs great 99% of the time...seems like something to do with load ? I'm stumped for now.
Old Mar 25, 2005 | 01:31 PM
Relic1's Avatar
22 - VTEC Oil Pressure Switch - defective circuit or unplugged / defective oil pressure switch
could be a sign that your oil pressure is dropping off for some reason.
I'd be looking at the connections, but you said you all ready checked those.
Old Mar 25, 2005 | 01:34 PM
VTiVTo8000rpm's Avatar
Default Re: Code 22 Weird Problem (Prod)
I'm in for this ...I have same problem code 22 VTEC oil pressure switch....my connections are all good also *shrugs*
edit: I hate that orange ******* engine light
Old Mar 28, 2005 | 10:05 AM
Prod's Avatar
Default Re: Code 22 Weird Problem (VTiVTo8000rpm)
somewhat of an update to this, I unplugged my vtec solenoid from the engine harness and started the car up...no ce light, I can't imagine thats normal behavior ?
Old Mar 28, 2005 | 10:36 AM
hatchi's Avatar
take off vtec solenoid and clean it. or try another one
Old Mar 28, 2005 | 11:30 AM
92b16vx's Avatar
Do you have a VAFC hooked up?
hondacurab16
Sep 21, 2005 11:00 PM
drudy
Aug 7, 2005 05:59 AM
pbizzlegsr
Oct 27, 2004 01:39 PM
JKim0901
May 8, 2003 12:41 AM
