Motor turns off once warm
Old Mar 25, 2005 | 12:41 PM
familyhauler's Avatar
Default Motor turns off once warm
LS motor shuts off when warm or when revved high, no check engine though?
Anyone have any ideas?
Old Mar 25, 2005 | 01:48 PM
Boostage's Avatar
Default Re: Motor turns off once warm (familyhauler)
first thing I would do is borrow an ecu and test it, if that fails i would check vacuum and fuel pressure.
Old Mar 25, 2005 | 07:30 PM
nota-ex's Avatar
Default Re: Motor turns off once warm (Boostage)
Does it cold idle okay?
Old Mar 26, 2005 | 07:24 AM
Default Re: Motor turns off once warm (nota-ex)
I've tried the ecu, i have an extra, same thing if i keep below mid-temp it acts normally, but anything after the car will shut off and/or have trouble turning back on, or turn on and immidiately back off it does this when mid-temp or after a high rev, after revving down it'll bog down then die or almost die out, i mean im getting fuel and ignition but something dying out i'll try the vaccum and fuel pressure test, but if either was off what would it be?
brandon_hatch
Apr 14, 2017 04:39 PM
HyperFlow
May 15, 2010 06:28 PM
Ruben19
Oct 11, 2006 08:30 AM
B_1_8_hatch
Apr 23, 2004 02:22 AM
AccrdATK
Oct 16, 2002 09:54 PM
