what wires do i tap on my dimmer switch for my gauge lights ?
Old Mar 25, 2005 | 10:57 AM
4DRmafia's Avatar
Default what wires do i tap on my dimmer switch for my gauge lights ?
i wanted to know what color wire do i tap in for my gauges to light up ?
Old Mar 25, 2005 | 11:06 AM
b16sellout's Avatar
Default Re: what wires do i tap on my dimmer switch for my gauge lights ? (SkipMic2006)
Indiglo Gauges?
Old Mar 25, 2005 | 11:09 AM
b16sellout's Avatar
Default Re: what wires do i tap on my dimmer switch for my gauge lights ? (b16sellout)
Old Mar 25, 2005 | 11:11 AM
4DRmafia's Avatar
eww not those man they are rice, but anyway no i got these oil presssure and water gauge
Old Mar 25, 2005 | 11:50 AM
Crx Jimmy's Avatar
just use a volt meter ant probe the wires, 12v constant is what you want if you get lower reading move dial and see if it fluctuates dont use that wire, should take 2 minutes, less time than it took you to post this
Old Mar 25, 2005 | 12:42 PM
Wes V's Avatar
Default Re: what wires do i tap on my dimmer switch for my gauge lights ? (Crx Jimmy)
The answer is in the string that rexwreck gave you.
But there is something that you have to know (or read between the lines), and that's in order to have the dimmer work, you have to hook up both the red/black wire and then the solid red wire to the other side of the light.
If the gauge "grounds" out the light to the body of the gauge, you can't get the dimmer function to work.
That solid red wire is a "variable ground" based on where the dimmer switch is positioned.
Wes
Dekorum
Jun 23, 2010 09:03 PM
Mr_ET
Nov 24, 2007 05:24 AM
c_buz
Audio / Security / Video
Jul 25, 2006 07:19 PM
1.8EG-T
Dec 28, 2004 01:23 PM
GDM Z28
Feb 27, 2004 07:00 PM
