to fix the rear camber
http://www.geocities.com/kingmantis81/rearcamber.html
will this method work for the R?
mine doesn't look exactly like this, but will putting new washers work with our R's?
[Modified by type R 599, 10:25 PM 1/25/2002]
kool, it doesn't have that much of a camber but its still a little noticable. i jsut want to get ride of the camber in the rear for now. the front doesn't look as cambered compared to the rear...
naw no trouble, i was just wondering will it work for my R coz that part on my car looks a little different. i was just making sure.
btw, thanks soo much for the link
. very helpfull
. very helpfull
no problem, just a couple of things, make sure all of the washers are the same thickness, and use grade 10.9 bolts, look in the yellowpages under bolts and nuts for the nearest specialty place that has them, they are hard to find
[Modified by xlr8 si, 10:43 PM 1/25/2002]
i will get an alignment soon.
lets say after i get an alignment, i put a camber kit on in the front, would i need another alignment after? and if i get an alignment now, and the camber is still there, will the camber eventually throw the alignment off? thanks
Wow..... talk about dodgy brothers..... Replacing chemcially harded bolts with (from the look of 'em) just any old bolt. As for his aligment process....that could still be out way more the 0.2+/- degrees.
I can't belive how some bods think of that sort of thing as saving money. If he got an aligment straight after he lower-it he wouldn't have scrubbed out his tyres..... Now there is a saving.
i probably will, but what if i cant get the camber kit soon?
xlr8 si, does the bolt have to be 45mm? will a 30mm one work?
or will a 10x1.5 40mm one work?
tia
tia
hrm...soo your telling me that if i gotten an alignment right after the got the springs in, it wouldn't camber?
...a little off topic, but maybe more on point for some... The JDM ITR's get tubular upper arms that allow a good bit less negitive camber in the rear... I forget how much less... We "no driving" Americans get stamped uppers with more camber to help our "inablity to drive". Anyone know how much difference in camber the JDM arms produce? Several people on the board sell them for around $100 with bushings... a far peice off from this topic, but a bit nicer...
EJK20R
Suspension & Brakes
Mar 19, 2006 10:26 PM
