can't get timing belt on. PLEASE HELP
Old Mar 25, 2005 | 10:04 AM
rough_draft's Avatar
Default can't get timing belt on. PLEASE HELP
I can't get my timing belt back on. I have loosened the tension pulley thing but i still can't get it to go on. Please help me out. Thanks guys
Old Mar 25, 2005 | 11:38 AM
PLAGUED_DB7's Avatar
Default Re: can't get timing belt on. PLEASE HELP (Lmaonade)
up for help for this guy
Old Mar 25, 2005 | 12:35 PM
mingbling96's Avatar
one thing i found useful is to make sure that the timing belt is on correctly on the 2 cam gears. then put a zip tie around the cam gear on each to keep the timing belt on.. that way, you don't have to worry bout the belt slipping on the cam gear when you try to slip it over other things. Give that a try.
Old Mar 25, 2005 | 02:21 PM
Finger Lickin' good's Avatar
Default Re: can't get timing belt on. PLEASE HELP (mingbling96)
Dam fool, you think we know what the problem is.
You cant get it on because it physically to small or something? You cant get it on because you dont have the knowledge? You need a helper?
There is a trick so to say. Remove one cam gear, probably exhaust, fit the belt up, then slide the cam gear back into place and whala.
Old Mar 25, 2005 | 02:26 PM
nsxtech's Avatar
Default Re: can't get timing belt on. PLEASE HELP (D-CeReaL#4)
You must push the tensioner pulley back away from the belt and snug the bolt up to get enough slack to put the belt on... you shouldn't have to remove any cam gears... Then re-loosen the tensioner bolt to allow it to tension the belt again once you have it on AND in correct timing....
Old Mar 25, 2005 | 02:45 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D-CeReaL#4 &raquo;</TD></TR><TR><TD CLASS="quote">Dam fool, you think we know what the problem is.
There is a trick so to say. Remove one cam gear, probably exhaust, fit the belt up, then slide the cam gear back into place and whala.</TD></TR></TABLE>
diaf
ty to everyone else
Old Mar 25, 2005 | 03:23 PM
yrethguad's Avatar
Default Re: can't get timing belt on. PLEASE HELP (nsxtech)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nsxtech &raquo;</TD></TR><TR><TD CLASS="quote">You must push the tensioner pulley back away from the belt and snug the bolt up to get enough slack to put the belt on... you shouldn't have to remove any cam gears... Then re-loosen the tensioner bolt to allow it to tension the belt again once you have it on AND in correct timing....</TD></TR></TABLE>
Yup, and if you have a problem getting the cams to stay still, there's a hole through them that will line up with a hole in the head, and you can use a punch to put through it to hold them still. I should have taken a picture during my belt change, and I could show you x-actly what I mean. I don't recall having to remove cam gears.
Just as a side, if you haven't already, It's commonly a good idea to replace the water pump while you're in there, just for some cheap preventative maintenance.
Old Mar 25, 2005 | 03:24 PM
yrethguad's Avatar
Default Re: can't get timing belt on. PLEASE HELP (yrethguad)
Sweet I'm no longer a trial user!
All these cool new settings, it's like Christmas!!!!
Old Mar 29, 2005 | 03:57 AM
yrethguad's Avatar
Got it on?
Old Mar 29, 2005 | 04:52 AM
SSBPGSR's Avatar
Default Re: (yrethguad)
slip it on the exhaust cam first
Devon M
Sep 30, 2014 04:30 PM
LSTurbo23
Jan 31, 2011 01:38 PM
NoVALude
Jul 19, 2006 11:53 AM
Lightning Lover.
Nov 30, 2003 06:46 PM
