Possible for a timing belt to be too tight?
Old Mar 25, 2005 | 08:44 AM
RTW DC2R's Avatar
Default Possible for a timing belt to be too tight?
Im guessing it is possible, but would it cause a problem? Like abnormal wear on the water or oil pump, or even too much tension that could rob some horsepower? Reason I ask is because I just retightened my belt, it was a little loose, and I also did a valve adjustment and fluid change. Now my car feels kinda sluggish. Im wondering if its related more to the valve tolerances which I did very tight but within spec, or maybe the belt is too tight.
One thing I did notice after tightening the belt, there is no "slack" feeling anymore and response is a bit more instant. sorta feels like I put a rear motor mount in.
Modified by RTW Ryan at 1:03 PM 3/25/2005
Old Mar 25, 2005 | 09:15 AM
Chris93Si's Avatar
Default Re: Possible for a timing belt to be too tight? (RTW Ryan)
A lot of people run them a little on the tight side intentionally I think, especially those running aftermarket cams. Kinda makes a supercharger-like sound when they're a little tight.
A little overtightened shouldn't hurt, just keep an eye on the belt for abnormal wear.
Old Mar 25, 2005 | 10:01 AM
GOGOMAIS's Avatar
It is a possiblity.
Old Mar 25, 2005 | 10:16 AM
mugenracer's Avatar
I believe a rule of thumb for tightness is that you should be able to twist the belt about 5mm-10mm, if the belt is too tight it will make a whining noise.
Old Mar 25, 2005 | 11:13 AM
RTW DC2R's Avatar
hmmm...maybe I should loosen mine a bit then. It has been known to make people think my car is supercharged and it definitely sounds like that now. Such a pain in the **** though and it seemd so loose I was worried about skipping teeth. ahhhhh.
Old Mar 25, 2005 | 11:16 AM
cmdr430's Avatar
Default Re: (RTW Ryan)
i also believe if you run the belt to tight, it puts to much stess on the cam caps and journals and could possibly cause them to wear unevenly and possibly break.....
Old Mar 25, 2005 | 11:23 AM
RTW DC2R's Avatar
I wish I had another R closeby to compare tensions with
Old Mar 25, 2005 | 11:31 AM
cmdr430's Avatar
i kept mine a little on the tight side..... "sort of a light humming sound".... and never had any problems, and i was also running spec b's......
you are probably fine.....
did you tighten it the old coat hanger way?
Old Mar 25, 2005 | 12:19 PM
RTW DC2R's Avatar
I tightened it by pushing up on the tension pulley some because im running a thin gasket and supposedly you cant just let the tensioner do its normal job of adjusting the tension. so you have to manually do it. wouldnt be so bad if it wasnt for the timing belt cover which has to be removed in order to access the pulley. which means you gotta remove the crank pulley, which means you gotta remove the flywheel cover, jam a screwdriver in ther, etc. lol PITA all for a little more compression
Old Mar 25, 2005 | 01:10 PM
Bbasso's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW Ryan &raquo;</TD></TR><TR><TD CLASS="quote">I wish I had another R closeby to compare tensions with </TD></TR></TABLE>
I could come up... Maybe Sunday
Old Mar 25, 2005 | 01:21 PM
RTW DC2R's Avatar
its good for now...ill compare when we get the meet set up.
Old Mar 25, 2005 | 05:56 PM
Kenso's Avatar
HT White Ops
When I was running my old R with the valves adjusted on the tight side, I noticed the same feeling of power loss. I readjusted them to the middle of specs. and the car felt normal again. My .02
Old Mar 25, 2005 | 07:16 PM
Black R's Avatar
25 Year Member
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW Ryan &raquo;</TD></TR><TR><TD CLASS="quote">I tightened it by pushing up on the tension pulley some because im running a thin gasket and supposedly you cant just let the tensioner do its normal job of adjusting the tension. so you have to manually do it. wouldnt be so bad if it wasnt for the timing belt cover which has to be removed in order to access the pulley. which means you gotta remove the crank pulley, which means you gotta remove the flywheel cover, jam a screwdriver in ther, etc. lol PITA all for a little more compression </TD></TR></TABLE>
.....try the coathanger method. It's a little harder to make it *too tight* that way...
I usually run more tension than the helms recommends, just to be safe. Also, because I change the belt more often than they recommend as well.
Old Mar 26, 2005 | 01:14 AM
DutchITR1689's Avatar
Default Re: (Black R)
Aren't there different stiffer springs from TODA or Spoon available for the tensioner?
In that case you can let the tensioner do the job if you have TODA cams or such....
Old Mar 26, 2005 | 04:02 AM
RTW DC2R's Avatar
Im not familiar with the coat hanger method. And I didnt realize aftermarket springs for the tensoner were available. Ill look into both. I drove it some last night, and Im guessing the sluggishness is more related to the valve tolerances. Kinda feels like I put my stock intake on and the top end is not as strong.
Old Mar 26, 2005 | 06:54 AM
b19coupe's Avatar
I also think that the "sluggish" feeling is more a function of the valve lash than belt tension. My belt sings.
Old Mar 28, 2005 | 07:58 PM
Brick Top's Avatar
re adjust your valve clearence, too tight
will cause some loss in power . i once over tightened
mine and it would barely idle along with the power loss.
Old Apr 12, 2005 | 04:07 PM
GS-Rcivic's Avatar
Default Re: (blacklist96)
hmm maybe thats where my supercharger sound is coming from, will check mine tomorrow.
Old Apr 12, 2005 | 04:19 PM
RTW DC2R's Avatar
by the way, I never loosened the belt, or changed the valve clearance...but I did readjust my base timing back to around 16 degrees, and it feels great again. i still have the supercharger whine though that seems to come and go.
Old Apr 12, 2005 | 05:01 PM
Alexander's Avatar
Default Re: (RTW)
Donde esta Dan GSR?
m4xwellmurd3r
Mar 10, 2013 06:58 PM
slide inside
Oct 22, 2009 09:25 AM
scartail
Apr 6, 2007 08:40 AM
obd2gsr
Dec 21, 2002 08:53 PM
