integra valves are "hydraulic" ??
Old Mar 25, 2005 | 08:08 AM
xstalkrx's Avatar
Default integra valves are "hydraulic" ??
Called to get a price estimate on a timing belt, water pump, and valve lash adjustment. They quoted me for labor on the timing belt and water pump, but on the valve lash, they were like "the valves are hydraulic so we just tighten them down." I dont know any better...is this true?
Old Mar 25, 2005 | 08:23 AM
Honda Hick's Avatar
Default Re: integra valves are "hydraulic" ?? (xstalkrx)
No, they are not hydaulic. The valve lash between the rocker and cam needs to be done manually. There is a adjustable screw for each valve that needs to be adjusted.
Old Mar 25, 2005 | 08:47 AM
sleeper96's Avatar
Default Re: integra valves are "hydraulic" ?? (Honda Hick)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Honda Hick &raquo;</TD></TR><TR><TD CLASS="quote">No, they are not hydaulic. The valve lash between the rocker and cam needs to be done manually. There is a adjustable screw for each valve that needs to be adjusted.</TD></TR></TABLE>
100% correct
Old Mar 25, 2005 | 08:52 AM
RidinStock's Avatar
Default Re: integra valves are "hydraulic" ?? (sleeper96)
The legends had a hydraulic system, the integra does not. What info did you give them? That's weird they would mix that up...
Old Mar 25, 2005 | 09:22 AM
skunked's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xstalkrx &raquo;</TD></TR><TR><TD CLASS="quote">Called to get a price estimate on a timing belt, water pump, and valve lash adjustment. They quoted me for labor on the timing belt and water pump, but on the valve lash, they were like "the valves are hydraulic so we just tighten them down." I dont know any better...is this true?</TD></TR></TABLE>
Don't bring your car there!!!!
Old Mar 25, 2005 | 09:49 AM
RidinStock's Avatar
Default Re: integra valves are "hydraulic" ?? (skunked)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunked &raquo;</TD></TR><TR><TD CLASS="quote">Don't bring your car there!!!!</TD></TR></TABLE>
Old Mar 25, 2005 | 10:29 AM
patmcd's Avatar
Default Re: integra valves are "hydraulic" ?? (RidinStock)
Maybe they thought you said that you had a legend. But still I wouldnt take my car there.
ejcivicdee
Nov 8, 2006 09:48 AM
philosofy1
21
May 19, 2006 07:34 AM
sinc747
Sep 25, 2005 06:27 PM
vxnine
12
Oct 14, 2004 07:41 AM
