2001 Accord V6 coupe, how much boost can the trans. take?
Old Mar 24, 2005 | 09:34 PM
GusRock77's Avatar
Default 2001 Accord V6 coupe, how much boost can the trans. take?
Old Mar 24, 2005 | 10:50 PM
honda_kid42's Avatar
Default Re: 2001 Accord V6 coupe, how much boost can the trans. take? (GusRock77)
the tranny is weak!!!! in most cases....autos suck!!!!!!
Old Mar 24, 2005 | 10:55 PM
Sex Cells's Avatar
Default Re: 2001 Accord V6 coupe, how much boost can the trans. take? (honda_kid42)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda_kid42 &raquo;</TD></TR><TR><TD CLASS="quote">the tranny is weak!!!! in most cases....autos suck!!!!!!</TD></TR></TABLE>
shut up...
im assuming 5 or 6, as long as your not really rough on it. and use the power more for highway passing then sprints
Old Mar 24, 2005 | 11:29 PM
The_Todd's Avatar
Farts in the shower
The 6th gens trannies are pretty damn weak, hell a lot of them have been replaced under normal driving conditions.
If you boost it reinforce the tranny, if you don't reinforce it get prepared to replace your tranny.
You may want to think about a tranny cooler and a tranny temp gauge. But if you touch that engine be prepared for honda to say no to your extended tranny warranty.
Old Mar 25, 2005 | 01:10 AM
CG2's Avatar
CG2
Default Re: 2001 Accord V6 coupe, how much boost can the trans. take? (.ken)
ive been on the same tranny for 97000... and still going... knock on wood!!!!
Old Mar 25, 2005 | 07:49 AM
-RedneckDave-'s Avatar
Working
Default Re: 2001 Accord V6 coupe, how much boost can the trans. take? (Se7ens Travels)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Se7ens Travels &raquo;</TD></TR><TR><TD CLASS="quote">
shut up...
im assuming 5 or 6, as long as your not really rough on it. and use the power more for highway passing then sprints</TD></TR></TABLE>
You obviously don't know how prone to failure the accord tranny's are. I would say that if you are experiencing any slippage at all on your automatic then It would not be the best idea to boost your motor. ALso I assume you are planning on getting the comptech supercharger for your method of boost considering that no one else makes anything for the j series. SO I would say get the trans. cooler and keep the trans. fluid changed a lot to help it last.
Old Mar 25, 2005 | 04:18 PM
lima, eh? youre well within driving distance. ignorance is not wanted.
Old Mar 25, 2005 | 09:50 PM
GusRock77's Avatar
Default Re: 2001 Accord V6 coupe, how much boost can the trans. take? ("Hites")
ive done some mods on my 6th gen and want to install a Comptech supercharger..but am scared that the tranny wont hold ...
*AEM CAI
*Comptech 4-2-1 header
*Custom piping with MagnaFlow Hi-Flow cat and Hi-Flow Y pipe; dual 5Zigen Fireball exhausts
*Unorthodox Ultra SS pulley kit (crank,alternator and P.S. pulley)
*GUDE Performance
-Ported and Polished Cylinder Head
-High Compression Radius Cylinder
-Racing Valve Grind
-Ported Intake Manifold
-Ported Throttle Body
-Camshafts
...and will be installing an AEM EMS by the end of the month ...but would the car be running too rich on boost? ...the comptech supercharger is said to boost 6psi and the Unorthodox pulley is said to add 3psi ...bumpin it up to 9psi ...
Old Mar 27, 2005 | 07:20 PM
GusRock77's Avatar
Default Re: 2001 Accord V6 coupe, how much boost can the trans. take? (-RedneckDave-)
...trans. cooler? ...who makes it? ..where can i get it? ...price? ...and how often should the fluid be changed?
Old Mar 31, 2005 | 03:54 PM
Whitesides's Avatar
Hayden makes one, B&M makes one.... you're probably looking at $150 - $200 for it.
Old Mar 31, 2005 | 09:30 PM
GusRock77's Avatar
Default Re: 2001 Accord V6 coupe, how much boost can the trans. take? (Whitesides)
where can i get it? ..web site??
Old Mar 31, 2005 | 10:45 PM
Working
Check the B&M website and you should find it. There is also one from comptech that is pretty much the same but you can say you have the comptech one.
Old Apr 1, 2005 | 08:21 AM
notoriousB's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GusRock77 &raquo;</TD></TR><TR><TD CLASS="quote">ive done some mods on my 6th gen and want to install a Comptech supercharger..but am scared that the tranny wont hold ...
*AEM CAI
*GUDE Performance
-Racing Valve Grind
-Camshafts
your transmission should be fine, the linear increase of a supercharger is going to be much nicer to your trans than the very fast spool of a turbo.
my question to you is how do you plan to run your auto transmission on the AEM EMS? It's not supported.
Old Apr 1, 2005 | 08:42 AM
GusRock77's Avatar
Default Re: 2001 Accord V6 coupe, how much boost can the trans. take? (notoriousB)
...just noticed that, but im told that the HKS F-Con Pro would do the job
Old Apr 1, 2005 | 12:10 PM
Whitesides's Avatar
or you could go with a Unichip. You can order them with preinstalled programs depending on your mods, and they won't break your bank.
Old Apr 2, 2005 | 08:14 PM
GusRock77's Avatar
...sorry, never heard of UniChip
Old Apr 2, 2005 | 11:25 PM
Legendaryyaj's Avatar
Youre the second guy Ive read that said he had the GUDE package. You might still be the same guy from before but I dont remember. How's the gains and have you dynoed it to get before and after hp comparisons?
If you want a tranny replacement get a Dr.Evil tranny to support the HP. Its rather pricey though but so is everything else for the AV6. Get a tranny cooler with filter and you *should* be fine. The 00-02 are said to be the weakest trannies so good luck on that.
Sidenote: I bet it was hard as hell to install that Comptech 4-2-1 header huh?
EDIT* I guess you're the same guy from before.
Old Apr 3, 2005 | 04:38 AM
audi_rs's Avatar
Default Re: 2001 Accord V6 coupe, how much boost can the trans. take? (Legendaryyaj)
if it helps, im on my 4th tranny right now, and no engine mods
Old Apr 3, 2005 | 05:19 AM
typhoon's Avatar
Default Re: 2001 Accord V6 coupe, how much boost can the trans. take? (audi_rs)
I though someone was coming out with a performance tranny for 6th gen V6?
Old Apr 3, 2005 | 09:28 AM
wj4's Avatar
wj4
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Whitesides &raquo;</TD></TR><TR><TD CLASS="quote">or you could go with a Unichip. You can order them with preinstalled programs depending on your mods, and they won't break your bank.</TD></TR></TABLE>
unichip is about $600-700 and is a great mod to do.
it really depends on your luck with your av6. i know someone with a 98 who is still on the first tranny and i know someone thats on 5th or 6th tranny.
i know someone who has a 01 av6 with the comptech supercharger pushing 12psi with unichip also.
av6 starts off with about 160hp to the wheel...after what my friend has done..all the minor bolt ons, supercharger and unichip.., hes up to 280hp to the wheel and 250 torque.
ps hes done all this for 2 yrs now and so far no problem. now hes looking a new project for auto-x. ae86 chassis with the new 2.2L s2000 engine
Old Apr 3, 2005 | 02:32 PM
YeuEmMaiMai's Avatar
the tranny in the 6th gen has the reliability of your average american car with a failure rate of between 4 and 5 % easily twice what honda's previous failure rates were. The V6 tranny from the 95-97 seems to be very strong and reliable.
Mr.Speed
Oct 30, 2005 03:20 PM
eg6r4eva
Mar 11, 2005 04:34 AM
phazebak
Sep 2, 2004 05:42 PM
JMD
Aug 20, 2003 10:25 AM
Harold
Apr 25, 2003 05:40 AM
