help hard time in and out of reverse
Old Mar 24, 2005 | 07:41 PM
93eg27's Avatar
Default help hard time in and out of reverse
i just noticed it after i raised my car about a half inch from the height i was at (because of my larger tires just got) and now i am having a hard time getting it into Reverse. then once it is in i have a hard time trying to get it out. any help would be great!!!!!
BTW: i have jdm b16a w/ ctr trans w/ kaaz lsd
if u need more info to help, let me know
Old Mar 24, 2005 | 07:53 PM
CerealWars's Avatar
Default Re: help hard time in and out of reverse (93eg27)
When you are trying to get it into gear and are having a hard time have you tried rocking the car back and forth? I know its a pretty common thing to have it be hard to get a Civic into reverse, but if you rock it alittle it will usally slide right into gear. Have you checked your tranny fluid? I know those Kaaz's require alot of mantience. Im just throwing out ideas.
Old Mar 24, 2005 | 08:20 PM
93eg27's Avatar
Default Re: help hard time in and out of reverse (CerealWars)
yeah i did rock it and put in 1st then reverse that usually works. i havn't checked my fluid guess i should. thanks
anyone else got any ideas
Old Mar 24, 2005 | 08:25 PM
jeffchaisi's Avatar
with the clutch depressed put in 3 gear then put in reverse 90% of the time works for me.
Old Mar 24, 2005 | 08:26 PM
adictionbass's Avatar
Default Re: (jeffchaisi)
i always slide it into 1st then reverse.
Old Mar 24, 2005 | 09:01 PM
93eg27's Avatar
Default Re: (adictionbass)
i am greatful for everyones advice, im sure if i mess w/ it enough, i could get it in gear when needed, but im trying to figure out why its doing this all of a sudden. i dont want to force it. i want it to be smooth like it was last week. thats why i bought all the good **** yaknow?
if it was like that from the time i installed everything then i would just get used to it but it was shifting in every gear perfect from day one (after build) this is a new thing
leeto206
Aug 18, 2012 11:21 PM
Hanmin
Oct 5, 2007 07:45 AM
TypeGSR196
Jun 7, 2006 05:03 AM
blktype-r
Jun 6, 2004 06:02 PM
