Building a ported enclosure
Old Mar 24, 2005 | 06:57 PM
zumiez007's Avatar
Default Building a ported enclosure
Alright, I've built several sealed boxes no problem, and completely understand calculating volume, and the basics. But I'm just getting bored and am wanting to try building a ported box to see if I can increase the SPL. I have 2 Pioneer TS-W33c subwoofers. I lost the manual a number of years ago, after building the boxes. My real question is how do I determine where and how to build the port? Some ports are rectangle and some are round, which is best? Thanks.
Old Mar 24, 2005 | 08:39 PM
zumiez007's Avatar
Default Re: Building a ported enclosure (zumiez007)
bump
Old Mar 25, 2005 | 07:50 AM
Gen2Integra23's Avatar
check out this web site: http://www.the12volt.com it is a good basic source site for building boxes
Old Mar 25, 2005 | 12:56 PM
Olegus's Avatar
Default Re: Building a ported enclosure (Gen2Integra23)
The speakers are TS-W303C i assume?
Shape of the vent doesn't matter, it's up to you. Dimensions matter though.
As for the box, my software suggests the following:
Type: Standard one-way driver
Company: Pioneer Electronics Inc.
No. of Drivers = 2
Mounting = Standard
Wiring = Separate
Box Properties (High Fidelity Variant)
Name:
Type: Vented Box
Shape: Prism, square (optimum)
Vb = 6.163 cu.ft
Fb = 26.82 Hz
QL = 5.878
F3 = 35.31 Hz
Fill = minimal
No. of Vents = 1
Vent shape = round
Vent ends = one flush
Dv = 127.5 mm
Lv = 190.3 mm
Box Properties (High Output variant)
Name:
Type: Vented Box
Vb = 2.008 cu.ft
Fb = 36 Hz
QL = 6.784
F3 = 52.28 Hz
Fill = minimal
No. of Vents = 1
Vent shape = round
Dv = 147.7 mm
Lv = 578.9 mm
The first variant has much better amplitude response curve.
Old Mar 25, 2005 | 03:33 PM
zumiez007's Avatar
Default Re: Building a ported enclosure (Olegus)
no, actually it is a TS-W33c sub. Not the 303c. It's a 450w sub. I cannot find the manual online or anywhere
Old Mar 25, 2005 | 03:46 PM
Auex's Avatar
You need the specs. Then download a program called WinISD. It is a box building program. Input the specs, set the tuning frequency, set the port size, and it will do the math for you. Also the type of port isn't really important, but calculating for the correct port is.
Old Mar 25, 2005 | 04:45 PM
zumiez007's Avatar
Default Re: Building a ported enclosure (Auex)
i said I don't have the manual, which has the specs, therefore i am asking you people for help.
Old Mar 25, 2005 | 10:04 PM
PupaScoopa's Avatar
Look here: http://www.thielesmall.com/
Old Mar 27, 2005 | 06:58 PM
tub_sephiroth's Avatar
Default Re: Building a ported enclosure (PupaScoopa)
subscribes
Old Mar 27, 2005 | 07:06 PM
Auex's Avatar
Default Re: Building a ported enclosure (tub_sephiroth)
I searched for about an hour with no results. Your best bet is to just call pioneer up and ask them. They should give the specs to you without a problem.
SpecialEdxl
Audio / Security / Video
Oct 14, 2005 04:46 AM
pnthr30
Jun 5, 2004 07:16 AM
ludeguy98
10
Apr 27, 2004 09:33 AM
Starrman85
17
Feb 3, 2003 02:42 AM
JTCdudeman
12
Dec 18, 2002 06:06 AM
