b16a1
Old Mar 24, 2005 | 06:15 PM
sycamore
Guest
Posts: n/a
Default b16a1
if any one had a good site to go to for instruction's on how to wire a b16a1
thank you...
Old Mar 24, 2005 | 06:18 PM
ACRProject's Avatar
Default Re: b16a1 (1slowsihatch)
http://www.hasport.com/Tech/Wring/EFSi-VTEC.PDF
Old Mar 24, 2005 | 06:45 PM
CRseXxy's Avatar
i dont know why this helped me but, start with the alternator, and just work ur way right. (if ur sitting behind the engine that is)
Old Mar 24, 2005 | 07:01 PM
89turboteg's Avatar
Banned
Im in the process of swapping a b16a1 into a customers 88 civic. The harness is pretty badly butchered so Im trying to find some info as well. What are you putting it in? The original engine in the car im doing was a D15 with throttle body injection. I think i have my work cut out for me. Oh yeah. its also an AUTOMATIC. not sure if that makes much of a difference.
Old Mar 24, 2005 | 09:36 PM
Rywire's Avatar
Default Re: (89turboteg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89turboteg &raquo;</TD></TR><TR><TD CLASS="quote">Im in the process of swapping a b16a1 into a customers 88 civic. The harness is pretty badly butchered so Im trying to find some info as well. What are you putting it in? The original engine in the car im doing was a D15 with throttle body injection. I think i have my work cut out for me. Oh yeah. its also an AUTOMATIC. not sure if that makes much of a difference.</TD></TR></TABLE>
You have a dpfi, so you have to do a mpsi swap on it, if you need we can do it for you at http://www.rywire.com yes, if its a auto, you will need to run 1 extra wire for the backup switch(you use the exhisting wire as well)
And to run vtec we also make a harness for that.
Ryan
Old Mar 25, 2005 | 11:05 AM
89turboteg's Avatar
Banned
Actually, the problem I am having is with the wiring of the transmission. The original transmission was automatic, and the B16 is also staying with the automatic transmission it came with. There are about 6 wires going to the transmission. Where can i find the schematics for the auto trans?
Old Mar 25, 2005 | 11:06 AM
89turboteg's Avatar
Banned
The engine is a 1mill series engine so its out of an integra. Is there anything to cross reference that with?
Old Mar 27, 2005 | 09:03 AM
Rywire's Avatar
The vss is located in the rear of the tranny, use you 88-91 tranny vss and use the cable operated system. That take care of 3 wires...
The backup switch has 2 wires, and the auto has 1, you have to run the extra wire for it to work.
Ryan
Old Mar 27, 2005 | 04:05 PM
89turboteg's Avatar
Banned
The newer tranny is also a cable vss, so there are no wires for that. I have solenoids aross the front, so these have to be powered by a ecu. I found out that I will have to use a 90-93 integra trans control unit as well as the shifter switch to tell the ecu what gear it is in. Not sure how im gonna get that to fit into the custom console already in the car but Ill get to that when i have to.
BigbamaBen
Dec 17, 2011 08:33 AM
MattsGreenEG
Sep 26, 2007 08:01 AM
flyingduck04
Nov 24, 2005 12:10 PM
94IntegraLs04
Aug 27, 2005 06:11 AM
danxdan
Aug 8, 2005 08:37 PM
