LS VTEC HELP PLEASE
dont need the year. big question is, what water pump and oil pump are you using?
if your using a ls pump you need a ls belt. using a gsr pumps you need a gsr belt. when i got my belt i just asked for a 93 gsr belt.
gsr water/oil pumps gears are bigger and the teeth are not the same as LS.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chriskona »</TD></TR><TR><TD CLASS="quote">dont need the year. big question is, what water pump and oil pump are you using?
gsr water/oil pumps gears are bigger and the teeth are not the same as LS. </TD></TR></TABLE>
preach it.... too true... i use a B18B1 and a B16A with ITR pumps. so i use ITR belts... works for me.
turbo_b16_ex
Oct 4, 2005 11:06 AM
