Suspension & Brakes Theory, alignment, spring rates....
how much for an alignment?
Old Mar 24, 2005 | 03:58 PM
jaycetan's Avatar
Default how much for an alignment?
i see all these signs for an alignment being 35 bux which i thought wasnt bad. but i found that alot of places wont do them for lowered cars. i have a lowered 92 civic hatch and bought it dropped. i found a shop and they told me 100 for the front and 100 for the back. does that sound right? how much did u guys pay?
Old Mar 24, 2005 | 07:16 PM
jaycetan's Avatar
Default Re: how much for an alignment? (jayce'shatch)
bump for OC
Old Mar 24, 2005 | 08:22 PM
Lord Helmet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jayce’shatch &raquo;</TD></TR><TR><TD CLASS="quote">i see all these signs for an alignment being 35 bux which i thought wasnt bad. but i found that alot of places wont do them for lowered cars. i have a lowered 92 civic hatch and bought it dropped. i found a shop and they told me 100 for the front and 100 for the back. does that sound right? how much did u guys pay?</TD></TR></TABLE>
Hell no I paid $50 max for a computerized laser assisted 4 wheel alignment at discount tires. $200 for a alignment= ripoff
Old Mar 24, 2005 | 10:22 PM
Circuit Star-29's Avatar
Default Re: how much for an alignment? (sleeperciv)
^^^ CHIT... I want to go to your shop...I can't get one for under 100 for all four
Old Mar 24, 2005 | 10:26 PM
travis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sleeperciv &raquo;</TD></TR><TR><TD CLASS="quote">
Hell no I paid $50 max for a computerized laser assisted 4 wheel alignment at discount tires. $200 for a alignment= ripoff </TD></TR></TABLE>
$200 is way too high, but you can't touch a 4 wheel alignment in these parts for $50. That's cheap. It would cost you more in the $90-100 range around here for the works. That's why I do it myself.
Old Mar 25, 2005 | 04:42 PM
jaycetan's Avatar
Default Re: how much for an alignment? (travis)
what do u mean the works? what should i make sure they do?
Old Mar 25, 2005 | 06:00 PM
travis's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jayce’shatch &raquo;</TD></TR><TR><TD CLASS="quote">what do u mean the works? what should i make sure they do?</TD></TR></TABLE>
I'm talking about an alignment done on a quality laser rack by people who can check and adjust camber, caster, and toe. If they can do that correctly, you'll get a print out of information including thrust angle and such. Naturally, on your Honda, the camber can't be adjusted with just OEM parts.
Old Mar 26, 2005 | 06:35 PM
garaged_Si's Avatar
My allignment is cost $40 only..... all 4 corners.
Old Mar 26, 2005 | 06:45 PM
jaycetan's Avatar
Default Re: how much for an alignment? (garaged_Si)
what car? was it a good job? and most importantly... where?
Old Mar 26, 2005 | 06:55 PM
GetawayInMoscow's Avatar
I'd say $70 and lower depending on where you live/where you go.
Old Mar 26, 2005 | 07:19 PM
Joon Joon's Avatar
Default Re: how much for an alignment? (GetawayinMoscow)
90 for a 4wheel alignment from westend alignment in gardena.. darren is tyte but hes like really backed up.. he was featured in like import tuner or super street, i cant remember...
Old Mar 26, 2005 | 07:59 PM
gabebauman's Avatar
Default Re: how much for an alignment? (vtecenjun)
I got a 3 year alignment plan today for $99.00 at TiresPlus.
Old Apr 27, 2005 | 12:20 PM
Fuster_Cluck's Avatar
Default Re: how much for an alignment? (gabebauman)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gabebauman &raquo;</TD></TR><TR><TD CLASS="quote">I got a 3 year alignment plan today for $99.00 at TiresPlus. </TD></TR></TABLE>
Does that equal unlimited alignments for 3 years? Is that a hook up or a deal anyone can get in on? Are you lowered? There are 5 TiresPlus in the Atl area
Shop here wants $70. No camber kits and I've always heard caster is NOT adjustable on Hondas (civic's to be specific). Just to get the toe put in spec is 70 bones here
I don't know why it matters if the vehicle is lowered or not. The only problem here I see is getting on to the ramps. The shop has wood boards to assist though. Other than that the 4 wheels are just mounted with some kind of funky square machine to the outer rim. Then the tech uses another lift to pick the front or rear chasis up off the ramp if needed.
Modified by Hybrid93Hatch at 9:13 PM 4/28/2005
Old Apr 28, 2005 | 01:26 PM
bad-monkey's Avatar
i pid 149.99 for lifetime alignments from firestone.
it's great.
Old Apr 28, 2005 | 05:13 PM
Default Re: (bad-monkey)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bad-monkey &raquo;</TD></TR><TR><TD CLASS="quote">i pid 149.99 for lifetime alignments from firestone.
it's great.</TD></TR></TABLE>
Not bad at all
Old Apr 28, 2005 | 07:48 PM
green-'s Avatar
Default Re: (Hybrid93Hatch)
$40 here for all four corners.
Old Apr 28, 2005 | 07:59 PM
Autoworks's Avatar
Default Re: (green00EX)
I charge $69.99 on lowered cars for a 4 wheel alignment. Its great if you have camber kits because the price includes all necessary adjustments to get it in spec. Without a kit on a Honda, its pretty much set the toe, set the psi, check for worn out parts and let it ride
20ls01
Suspension & Brakes
Jan 11, 2008 01:52 PM
ware
Suspension & Brakes
29
Dec 19, 2007 09:01 AM
vi3tromanc3r
Suspension & Brakes
18
Apr 19, 2007 09:32 AM
kasperxtcy
Suspension & Brakes
Mar 31, 2007 11:30 PM
Reservation-Sensation
Mar 4, 2005 06:25 AM
