Tranny problems
Old Mar 24, 2005 | 02:05 PM
DailyBlown's Avatar
Default Tranny problems
I need you guys to educate me on the B16A SiR II tranny...I am not sure which tranny I have, I think it is either the hydraulic tranny S21 or Y21...I want to replace the synchros, clutch, fly wheel and rear main seal... Can I go to an American Honda dealership and get parts for it? Or any websites that you guys recommend? Finally I remember when I was doing the motor swap with my friends someone took the sticker off that identifies the tranny is their anyway to tell without it?
Old Mar 26, 2005 | 01:56 PM
DailyBlown's Avatar
Default Re: Tranny problems (DailyBlown)
bump
Old Mar 26, 2005 | 01:58 PM
VTiVTo8000rpm's Avatar
Your an '02 member and yet you didn't search
edit: I'm pretty sure if you got the A2 usdm then you have a hydro tranny, just no lsd ....don't quote me on this tho
Old Mar 26, 2005 | 02:04 PM
DailyBlown's Avatar
Default Re: Tranny problems (VTiVTo8000rpm)
I did search, however, I couldn't find the difference between the two trannys....I am assuming one has LSD (Y21?) and the other (S21 ) doesn't...
Old Mar 26, 2005 | 02:06 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DailyBlown &raquo;</TD></TR><TR><TD CLASS="quote">I did search, however, I couldn't find the difference between the two trannys....I am assuming one has LSD and the other doesn't...</TD></TR></TABLE>
not necessarily...you can have a cable tranny w/ lsd, and you can have hydro tranny w/o lsd, or vice versa
I asked the same thing acouple weeks ago because I wasn't sure what tranny I had either, but I found out I have hydro trans w/ lsd
I'll try and post the link...not to good at that tho
Old Mar 26, 2005 | 02:16 PM
DooD SEARCH...I just entered in "keyword"-tranny, for THIS forum....recent content and came up with like 200 posts
ludatic98
Jan 25, 2007 05:35 PM
DJ KrunchyKracker
Jan 7, 2002 03:58 PM
