a6 injectors in JDM D15B sohc vtec rail?
will this work? im working on swapping the engine and i want to use the obd0 fuel injectors...mainly for the resistor box cause im gonna turbo it later ill be converting to obd1 using a conv harness and a p28ecu, but i want to use the obd0 fuel injectors on the obd1 fuel rail...will that work or will i have to use a d16a6 fuel rail? im converting my dx to si wiring so i dont have a d16a6 fuel rail to start off with. i can buy fuel injectors on ebay for cheap and i just want to know if they will fit on the jdm d15b fuel rail? THX
yes you will need to use the D16A6 injectors and FPR (fuel pressure regulator) trust me you will see why. I did this on my D15B VTEC swap last weekend. Tomorrow night I am hooking up the conversion harness to plug in my P08 ECU woohoo
the a6 pressure regulator? dont i have to use the vtec one since i know the vtec engine runs at a diff fuel pressure? so i can use the a6 fuel injectors on the jdm d15b fuel rail right?
