B16 in a 4x4 Suzuki?
Old Mar 24, 2005 | 08:28 AM
lsvtec2000SI's Avatar
Default B16 in a 4x4 Suzuki?
I just got a wild hair. Is it possible to stick a B16 in a Suzuki Samurai? If so what's involved? I would love to have vtec honda power in my rock smasher.
Old Mar 24, 2005 | 09:04 AM
david@didrace.com's Avatar
Default Re: B16 in a 4x4 Suzuki? (lsvtec2000SI)
Rock crawling with no torque. Sounds like fun.
Old Mar 24, 2005 | 09:31 AM
ManBearPig4silly's Avatar
through in a b20z
Old Mar 24, 2005 | 09:39 AM
civicross's Avatar
Default Re: (silly4lude)
350 Small block chevy
Old Mar 24, 2005 | 10:55 AM
Default Re: B16 in a 4x4 Suzuki? (backpurge)
Touque is in the gears!
I already have a b16 sitting in my garage...
Old Mar 24, 2005 | 10:57 AM
Default Re: (civicross)
Too heavy overrated. I want a light high revving honda vtec motor.
Old Mar 24, 2005 | 11:18 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsvtec2000SI &raquo;</TD></TR><TR><TD CLASS="quote">Touque is in the gears! </TD></TR></TABLE>
That's cute.
Old Mar 24, 2005 | 12:01 PM
Importracer_001's Avatar
A friend of mine has a B16 turbocharged in a suzuki swift gti
Fabricated everything on his own
Old Mar 24, 2005 | 12:21 PM
underpressure02's Avatar
i was going to put the rx7 twin turbo motor in my suzuki sammy but I could not figure out a way to get the 4x4 to work. So I dropped the project.
Old Mar 24, 2005 | 12:46 PM
sohcvtec66
Guest
Posts: n/a
Tell me your kidding .......RIGHT ?
Old Mar 24, 2005 | 01:41 PM
Default Re: (Importracer_001)
Any pictures? what was involved?
Old Mar 24, 2005 | 01:43 PM
Default Re: B16 in a 4x4 Suzuki? (sohcvtec66)
Any thing is touqueyer than my 1.3L carburated w/ 64hp
Old Mar 24, 2005 | 01:59 PM
Default Re: B16 in a 4x4 Suzuki? (underpressure02)
The best way to stick a RX7 motor in would be with the tranny & just run a short driveline to the divorved tranny.
How about a Chevy big block. More HP and TQ than any mild Honda engine and cheaper too, you can get a running 454 from a junkyard for like $500.
Old Mar 24, 2005 | 02:33 PM
Only $500 for a bigblock but another $3000-$5000 for the drivetrain to support it. Plus I want keep it light w/ stock drivetrain just a little more power. Thanks for the idea though.
Old Mar 24, 2005 | 03:16 PM
FormulaGSR's Avatar
anything is possible, but probability is a different story. Somunds like a bad idea. THe 4.3L chevy motor seems to be a comon swap. it think there are kits for it off the self. that would be my choice. the b16 would suck
Old Mar 24, 2005 | 07:07 PM
Infinite Auto's Avatar
Default Re: B16 in a 4x4 Suzuki? (FormulaGSR)
with the right gearing you could make a brigs 5 horse move your sammy over rocks......im not at all into trucks but a few buddys of mine are into the toyota and suzuki thing and rock the dual cases. there you can put the truck in first and let it idle and walk next to the truck......at like 4k in first they are going like 6mph lol.....a b16 would be a huge step up from a sammy motor......ive seen there samurai's with just gears go over some pretty crazy *** ****.....have fun, id think maybe you could make an adapter plate kinda like the h22/bseries one......mounts would just be made up but it would be pretty nice
Old Mar 25, 2005 | 05:16 AM
egizzle8
Guest
Posts: n/a
Default Re: B16 in a 4x4 Suzuki? (B18TurboEF)
Good luck getting the tranny to work since the engine is mounted the direct opposite. I would go with the rotary setup over a b16. it's smaller also so should be easier and you can keep it carb'd since the 13b has carb support if you wanna make it easier then turning your sammy into EFI. Rotaries are like the bitch engine and get put in everything! There's a mag out that is just rotary powered cars and it's not just RX7's. You'd be suprised. If you would more set on the b16 then you'd be better off with a B20 4wd tranny but it's all up to you if you want to keep 4wd. Don't sammy's use solid front axle too and not independent susp.?
Old Mar 25, 2005 | 05:44 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsvtec2000SI &raquo;</TD></TR><TR><TD CLASS="quote">Only $500 for a bigblock but another $3000-$5000 for the drivetrain to support it. Plus I want keep it light w/ stock drivetrain just a little more power. Thanks for the idea though. </TD></TR></TABLE>
Why in hell would a drivetrain cost that much? You can probably find a mid-70's 4wd big block Chevy truck for like $1000 in a junkyard.
I can tell you're not a subscriber of the 'no replacement for displacement' logic. It's crazy when I see people on here happy as hell when they gain 20 hp or so off of their stock 113 hp beast, when in all reality, I can spend less than a grand swapping a bigger motor into a car/truck and have a little under 400 hp... reliably. No lifting heads, no blown gaskets, just stock horsepower from an engine created before ecu's and distributorless ignitions.
Old Mar 25, 2005 | 06:03 AM
egizzle8
Guest
Posts: n/a
I wouldn't mind a bigblock but damn that would be like half the weight of the sammy! lol. I know it wasn't in your options but I think the 13b would be the best.
http://hometown.aol.com/suzuki13brotary/
Old Mar 25, 2005 | 06:08 AM
Default Re: B16 in a 4x4 Suzuki? (egizzle8)
If you have enough horsepower weight isn't as much of an issue.
Old Mar 25, 2005 | 01:14 PM
Smokinsax's Avatar
The Boot
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by backpurge &raquo;</TD></TR><TR><TD CLASS="quote">That's cute.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcvtec66 &raquo;</TD></TR><TR><TD CLASS="quote">Tell me your kidding .......RIGHT ?</TD></TR></TABLE>
Old Mar 25, 2005 | 01:42 PM
accord387's Avatar
weight always matters. You dont need a big block to move a samurai, short gears and the stock bitch as motor can make those things do some crazy ****. Now if we're talking about some old hunk of steel truck then maybe a big block is needed. Yet its still fun to see those big *** heavy trucks stuck and a lil sammy cruising by.
Old Mar 25, 2005 | 01:56 PM
Default Re: B16 in a 4x4 Suzuki? (accord387)
Hell yeah! now that's what I'm all about. Out wheelin drinkin have a good time crusin ( in my $2500 fully built locked & geared sammy) by these $30000 Rigs while they're all pissed off breakin parts. LOL
