a good clutch for a d15vtec with greddy kit
i noticed my clutch slip a little yesterday and i was wondering what a low cost clutch would be good for the power in am making. Right now i have a centerforce II with a ACT streetlight flywheel. i am running the kit at stock settings so i should not have more then 150whp... so what is out there and what works for others
I run a Greddy kit on my EG civic, and I noticed the clutch didn't last long after. I replaced it with an 'Action' kevlar clutch and I couldn't be happier. I went with kevlar, b/c it will take a beating.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cxjon »</TD></TR><TR><TD CLASS="quote">how much are they?</TD></TR></TABLE>
~$240
Check ebay for the user "clutchcityonline" Thats where I got mine...he's a good seller
~$240
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG6Honda »</TD></TR><TR><TD CLASS="quote">I run a Greddy kit on my EG civic, and I noticed the clutch didn't last long after. I replaced it with an 'Action' kevlar clutch and I couldn't be happier. I went with kevlar, b/c it will take a beating.</TD></TR></TABLE>
dont belive the hype. my action kevlar disc lasted 4 months. my cm stage 4 lasted about 12, and it took way more beatings than that kevlar ****.. once you do a couple hard drag launches that extreme heat that kevlar disc will cause it to slip. that right there takes years out of its life. organic or puck type clutches get my vote.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cxjon »</TD></TR><TR><TD CLASS="quote">i noticed my clutch slip a little yesterday and i was wondering what a low cost clutch would be good for the power in am making. Right now i have a centerforce II with a ACT streetlight flywheel. i am running the kit at stock settings so i should not have more then 150whp... so what is out there and what works for others</TD></TR></TABLE>
is the stage 2 centerforce clutch not enough? i thought that would be plenty of clutch for up to at least 170whp. are the centerforce clutch's not the good or what? would u not suggest i get one?
its been thru alot and a few differnt motor set ups i had and pretty much beat to ****. i had it for three years so its done its time! i likes the clutch i just wanted something different.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cxjon »</TD></TR><TR><TD CLASS="quote">its been thru alot and a few differnt motor set ups i had and pretty much beat to ****. i had it for three years so its done its time! i likes the clutch i just wanted something different.</TD></TR></TABLE>
ooo ok i understand, i was planing on using this for my setup n/a for awhile then turbo it. i have the zex59300 cam and valve springs.
whast the whp rating on that clutch do u know? so u would recomend it then?
