F22B Motor
I have a 92 prelude with a F22B motor swap. The swap came with the car. My question is my starter went bad and i wasn't sure if the starter for the H series was the same as the F series and if they are different where can i find an F22B starter because they were only made in Japan. I'm pretty sure the F series single over head cam vtec motor doesn't match up but i'm not 100%.
I would think the starter is the one that goes to the tranny more than the engine but I would take the old one out and bring it to the auto parts store with me. Compare it with the new one and see which one it is. Post back here with results.
im not sure about which starter to get, but the jdm f22b is basically an h23 head on an f22 block, you can use all the h23 valvetrain components (if you compare the stock parts they are exactly the same), and for the block, just use f22 botom end components . . . i wish i could help you out with the starter tho
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdmaccordfreak »</TD></TR><TR><TD CLASS="quote">if it helps, i am running off an h23 starter myself. it works just fine</TD></TR></TABLE>
I remember reading that the alternator or PS pump is the only parts NOT H23. everything else is compatible.
Starter is not based on displacement.
