Master Clutch Cylinder Replacement
i think i have my master clutch cylinder leaking. the resivoir is empty and i can see the clutch fluid inside the car were the clutch pedal is. do i need to replace the whole master clutch cylinder or just some lines? thanks in advance
-denny
-denny
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kendall »</TD></TR><TR><TD CLASS="quote">In this case I believe the master cylinder is indeed going to need a replacement.</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by uzabatty »</TD></TR><TR><TD CLASS="quote">my mechanic told me I would have to do mine soon too cause it's starting to leak... hope it's not too expensive</TD></TR></TABLE>
ive got fluid all around my pedals too, would clutch fluid be the only culprit?
also i think there is prob an article on team-integra about the replacement.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rufridn »</TD></TR><TR><TD CLASS="quote">mine is leaking too. i know theres 2 bolts, i forogt how its connected to the clutch pedal.</TD></TR></TABLE>
there's a pin that goes through the cylinder and the clutch pedal... pin goes through both, then is held there by a cotter pin...
it's really not that difficult... hardest part for me was breaking the line loose off of the MC...
-Mike
-Mike
ZenDynasty
24
Jun 1, 2008 07:56 PM
correct. the seal in the mastercylinder is leaking. Replace the MC and youl be good to go.
