Will an Exedy Organic Clutch hold?
Old Mar 23, 2005 | 07:08 PM
dand39's Avatar
Default Will an Exedy Organic Clutch hold?
Basically, I need to change my clutch in preparation to the JUN cams going into my JDM H22. I want something that'll keep the stock feel and effort, and hold the hp/tq that it'll *potentially* produce. So with that said...
Would an Exedy Organic clutch hold the tq? Would I be cutting it a little close? I've read people mention Exedy "Stage II" clutches... what are those? The cerametallic?
Any useful information is appreciated, thanks.
Old Mar 23, 2005 | 08:12 PM
precord96's Avatar
Default Re: Will an Exedy Organic Clutch hold? (dand39)
I've been running on an Exedy Organic for a while with Jun cams, and it holds well enough. It's a good streetable clutch and I believe it can hold the power well.
Old Mar 23, 2005 | 10:24 PM
PrettyLude's Avatar
it will hold it
Old Mar 23, 2005 | 11:09 PM
lenn's Avatar
i've been expereincing a lot of cold clutch chatter with mine... its really annoying and a bit unnerving, its been about 6000 miles... doesnt seem like the chatter is gonna go away...
Old Mar 23, 2005 | 11:49 PM
TimeRacer's Avatar
Almost NOTHING you will do to an N/A you'll have to worry about the Exedy Racing Organic holding the power. What you need to worry about is if you're trying to do launches with it. If you're going to be doing drag launches with it then you're going to want to upgrade to a Kevlar or ceramic pucked clutch. They handle drag launches much better than organic. I believe that the Exedy is rated up to 200 ft/lbs of torque which I highly doubt that you'll get close to.
Old Mar 24, 2005 | 12:14 AM
edulerp97's Avatar
Default Re: Will an Exedy Organic Clutch hold? (TimeRacer)
How about a clutch from clutchmasters...Really good clutches...Stage 3 would fit your application...
Old Mar 24, 2005 | 04:47 AM
Dougs96SI's Avatar
Default Re: (lenn)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lenn &raquo;</TD></TR><TR><TD CLASS="quote">i've been expereincing a lot of cold clutch chatter with mine... its really annoying and a bit unnerving, its been about 6000 miles... doesnt seem like the chatter is gonna go away...</TD></TR></TABLE>
Ive had the same experience with mine, when its warm it is awesome!!!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by edulerp97 &raquo;</TD></TR><TR><TD CLASS="quote">How about a clutch from clutchmasters...Really good clutches...Stage 3 would fit your application...</TD></TR></TABLE>
Clutchmasters stuff is pretty nice, overall im pleased with my stuff
Old Mar 24, 2005 | 05:50 AM
Ministry's Avatar
Default Re: (lenn)
yea my exedy organic mated to an 8lb fidanza flywheel is loud as ****. chatters at low RPM when cold, and makes a rukus when I let up off the gas on the highway. The flywheel came with documentation that specifically said noise from the transmission will be increased, so I guess its all normal.
I'm happy with the performance. It would probably be much quieter on the stock flywheel.
Old Mar 24, 2005 | 10:35 AM
edulerp97's Avatar
Default Re: (dreamer)
Clutchmasters and fidanza flywheel are the perfect match.....had no problems with that so far....
Old Mar 24, 2005 | 01:41 PM
dand39's Avatar
Default Re: Will an Exedy Organic Clutch hold? (edulerp97)
Thanks for the responses everyone. I have couple more questions, though...
CM looks pretty good. Would the Stage 2 or 3 require a break in period? How's the pedal feel? Any chatter? Would I be able to "ride" the clutch? I prefer to feather my launches, rather than dropping the clutch. Thanks for the help.
Modified by dand39 at 2:55 PM 3/24/2005
Old Mar 24, 2005 | 02:05 PM
AndyD's Avatar
If you are NA, the Exedy Race clutch is MORE than enough. They are the best priced too. Anything else is a waste.
Old Mar 24, 2005 | 06:33 PM
edulerp97's Avatar
Default Re: Will an Exedy Organic Clutch hold? (AndyD)
of course in his opinion.....
Old Mar 24, 2005 | 11:06 PM
precord96's Avatar
Honestly, I haven't run anything but Exedy in my car and I'm a satisfied customer.
Yeah it does chatter alot when cold (plus I have es inserts which doesn't help), but it grabs well and it is priced better than others. You have to sacrifice a little for any clutch.
And yes there is a break-in for any type of clutch.
Old Mar 25, 2005 | 08:52 AM
gerhard's Avatar
Default Re: Will an Exedy Organic Clutch hold? (precord96)
Exedy makes the OEM clutch disc for the Honda's....
The OEM clutch disk and pressure plate will be fine... really.
I did notice that the fidenza lightened flywheel helped the shift quality on the prelude.
pjr710
Jul 23, 2008 09:53 AM
kelvinchau25
Sep 12, 2007 01:57 PM
91crxturbo
Dec 16, 2006 07:17 PM
Muckman
Jun 17, 2004 04:57 PM
ALF
Nov 30, 2001 09:58 PM
