HOW IS YOU FPR HOOKED UP ON YOUR SWAP?????????????????
Old Mar 23, 2005 | 05:18 PM
88cerx's Avatar
Default HOW IS YOU FPR HOOKED UP ON YOUR SWAP?????????????????
just like it says did you hook up to the purge valve or to a nipple on the intake mani???
and also why did you hook it up there would it run differently if hooked up either of those two ways
Old Mar 23, 2005 | 08:09 PM
88cerx's Avatar
Default Re: HOW IS YOU FPR HOOKED UP ON YOUR SWAP????????????????? (88cerx)
c'mon guys every one has one so HOW IS IT HOOKED UP please help
Old Mar 23, 2005 | 08:18 PM
Redline130's Avatar
My FPR is hooked up to the intake manifold. I think as long as there is a vaccum, it will work the same. Not too sure about the purge valve though.
Old Mar 23, 2005 | 08:23 PM
88cerx's Avatar
Default Re: HOW IS YOU FPR HOOKED UP ON YOUR SWAP????????????????? (Redline130)
this is where i got my info from http://b16a.honda-perf.org/Tech/vacuum.jpg
isn't there a preasure valve on the si???????????
Old Mar 24, 2005 | 09:18 AM
88cerx's Avatar
Old Mar 24, 2005 | 09:47 AM
Crx Jimmy's Avatar
just hook it up directly to the manifold, that is a integra picture looks like the one under the hood on my 91 teg, on my b16 the hose is like 3 " long it goes from the fpr to a nipple in the manifold above the intake temp sensor
Old Mar 24, 2005 | 09:48 AM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
That is the stock vacuum map for an '88 Si in case you don't have one..
Hook it up as close to stock configuration as you can and it should be OK..
FPR>I would just hook it to manifold vacuum..
wasapyt
Jul 20, 2010 03:37 AM
omyhonda1
Jan 24, 2010 10:24 AM
T-CHUK
May 4, 2007 05:28 PM
tony
Jan 31, 2004 11:21 AM
