Help me squeeze some more hp out of my GSR All motor setup...please.
Old Mar 23, 2005 | 02:38 PM
98vsmferio's Avatar
Default Help me squeeze some more hp out of my GSR All motor setup...please.
I have a B18C1 in my 98 ferio which has the following done to it:
CTR cams
ITR valvetrain
Buddy club cam gears
Skunk2 intake manifold
Bored out GSR tb to 64 mm (to match skunk2)
AEM ITR CAI
DC 4-1 header
ES oval exhaust w/ 2 1/4" piping w/ carsound cat
Hondata S200 system
I had the car tuned by Church and my numbers were
189.1 whp/ 140.6 tq.
I would like to squeeze 11 more hp out of her to get to that 200 whp mark. Any ideas??
I am currently in the process of fixing my tranny up with lsd and a new clutch/flywheel setup but I still want to get that 11whp more out of her.
Any ideas are greatly appreciated...THANKS
Old Mar 23, 2005 | 02:40 PM
2k.civic.si's Avatar
Default Re: Help me squeeze some more hp out of my GSR All motor setup...please. (98vsmferio)
get rid of the dc sport 4-1 header and buy a better one....an-r or rmf or smsp all make headers that should put you up there
a hotter set of cams would also put you up there
Old Mar 23, 2005 | 02:58 PM
Professor15's Avatar
Default Re: Help me squeeze some more hp out of my GSR All motor setup...please. (2k.civic.si)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2k.civic.si &raquo;</TD></TR><TR><TD CLASS="quote">get rid of the dc sport 4-1 header and buy a better one....an-r or rmf or smsp all make headers that should put you up there
a hotter set of cams would also put you up there</TD></TR></TABLE>Sunk2 stage 2, jun 3 or toda c, thats if you want to upgrade the valvetrain, but if you dont i think you can run the bcIII+ with just itr valvesprings, correct me if im wrong. But an anr, smsp, hytech, or dtr header along with ATLEAST a valvejob and some higher compression will get you past that mark along with more tuning. You can get higher compression with ITR pistons or milling the head, thinner headgasket or flat-top valves. so yea you have alot of choices just depends on your budget...
Old Mar 23, 2005 | 03:24 PM
Default Re: Help me squeeze some more hp out of my GSR All motor setup...please. (drchulo)
ya sadly his options are all costly...but if you look at people who race motorcycles they pay hundreds for a just a few more hp...so it could be worse
Old Mar 23, 2005 | 03:26 PM
spooncivic1's Avatar
are you still running stock compression. i would at least mill the head, when you are putting in your new valvetrain for some BC3+'s
Old Mar 24, 2005 | 12:58 AM
98vsmferio's Avatar
up
Old Mar 24, 2005 | 01:19 AM
UNKNOWN_MEMBER's Avatar
doesn't the dynapack read kinda high? If so, how high? How long did it take him to tune your car and how much did he charge you? Im thinking of taking my next motor there.
Old Mar 24, 2005 | 01:27 AM
ce's Avatar
ce
get a toda header.My guess it you'll get close to 11hp more just with that
Old Mar 24, 2005 | 03:59 AM
evilricer's Avatar
Default Re: (ce)
would a greddy 4-2-1 2-piece header be better than the jdm itr??
Old Mar 24, 2005 | 05:51 AM
null.'s Avatar
Default Re: (UNKNOWN_MEMBER)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UNKNOWN_MEMBER &raquo;</TD></TR><TR><TD CLASS="quote">doesn't the dynapack read kinda high? If so, how high? How long did it take him to tune your car and how much did he charge you? Im thinking of taking my next motor there.</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=703749
reads about 10 hp more give or take a little less
Old Mar 24, 2005 | 08:03 AM
CHEETAH's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vsmferio &raquo;</TD></TR><TR><TD CLASS="quote">
DC 4-1 header
w/ carsound cat
go witht he cheap HyTech for $799 that Endyn sells and drop the cat for the dynotune ... it'll hit 200. not sure if you put 93/94 octane fuel, if you did I'm sure shawn would go a bit more aggressive on the timing and give you two maps, one for low octane and one for 93/94
greg
Old Mar 24, 2005 | 12:56 PM
properly adjust dynapack will read the same as a dynometer if its setup correctly...
Old Mar 25, 2005 | 05:07 PM
Mattb16teg's Avatar
Community Builder
Community Influencer
Default Re: (2k.civic.si)
More compression, bigger cams, = over 200.
jAyee124
Jul 8, 2012 10:28 PM
snk808x
Nov 4, 2009 11:31 AM
B18C1NMotion
Jan 17, 2007 06:37 PM
gsrxxdc2
Jun 30, 2004 08:15 PM
Drizzo
20
Feb 25, 2004 12:41 AM
