is a b16 with ctr pistons, bcIII cams and tuned with vafc recomended..
i was planning this setup on my 00si..
omni valve springs and retainers, fpr,
cam gears and type r header.
i just want something mild and daily driven.
Modified by numbnut at 8:17 PM 3/23/2005
id definitely recommend getting it tuned even if its only a vafc. It has a big dropoff in the midrange if untuned.
10.8? try 11.43 according to Omniman in the pct post.I believe a b16b is 10.8.NO,dropping PCT's in a b16a will NOT give you the same comp ratio as a b16b
