drag slicks for crx?
Old Mar 23, 2005 | 01:33 PM
honda06si's Avatar
Default drag slicks for crx?
i posted this in the wheels/tire forum but no luck.
i found 3 diffrent sets of drag slicks and i have a crx with a b16 so i was wondering which size would fit best....ive never used drag slicks so i am unfamiliar with them.
22.5x7.5x13
20x7x13
22x9x13
my car is lowered about 2 inches. oh and i am only buying slicks for the front
Old Mar 23, 2005 | 01:59 PM
kaoss_11's Avatar
B A N N E D
You will have to raise the vehicle and it depends on the hp you have. details on ur setup would help
Old Mar 23, 2005 | 02:04 PM
86si's Avatar
Default Re: drag slicks for crx? (honda90si)
if your car is all motor i'd go with M&H 22s. also your gonna need wheel spacers to run a 9" rim & tire. you may have to raise it a little
Old Mar 23, 2005 | 05:46 PM
honda06si's Avatar
Default Re: (kaoss_11)
hp ummm to the wheels prolly 140
Old Mar 23, 2005 | 05:56 PM
honda06si's Avatar
Default Re: (honda90si)
if i get the 20x7x13 or the 22.5x7.5x13 will i need wheel spacers or to just raise it?
also will the 22.5x7.5x13 fit on the steelie?
Modified by honda90si at 10:16 PM 3/23/2005
Old Mar 23, 2005 | 07:01 PM
honda06si's Avatar
ttt
Old Mar 23, 2005 | 08:21 PM
Redline130's Avatar
22x8x13's should work fine for you. Just get some Lenso's from Wil at Exospeed (I think he still has a sale going on).
Here's the link: https://honda-tech.com/zerothread?id=1148763
Old Mar 23, 2005 | 08:25 PM
90sohcHATCH's Avatar
Default Re: drag slicks for crx? (Redline130)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Redline130 &raquo;</TD></TR><TR><TD CLASS="quote">22x8x13's should work fine for you. Just get some Lenso's from Wil at Exospeed (I think he still has a sale going on).
Here's the link: https://honda-tech.com/zerothread?id=1148763</TD></TR></TABLE>
Old Mar 24, 2005 | 12:02 PM
efrex's Avatar
i bought bfgoodrich drag radials 205/50/14 mounted on stock blackies..i use em only when im at the track..i have a 91 crx si with b16.lowered
Old Mar 24, 2005 | 09:00 PM
honda06si's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda90si &raquo;</TD></TR><TR><TD CLASS="quote">also will the 22.5x7.5x13 fit on the steelie?</TD></TR></TABLE>
Old Mar 24, 2005 | 10:31 PM
kaoss_11's Avatar
B A N N E D
i believe not
Old Mar 24, 2005 | 11:07 PM
*Boostwerks*'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda90si &raquo;</TD></TR><TR><TD CLASS="quote">if i get the 20x7x13 or the 22.5x7.5x13 will i need wheel spacers or to just raise it?
Modified by honda90si at 10:16 PM 3/23/2005</TD></TR></TABLE>
Spacers will be determined by what wheel/brake caliper combo you run. But...if your running the stock brakes, pretty much any wheel will work.
And, Yes you can run those on steelies. Just make sure the steelie is wide enough for the tire (6" min), although I don't neccasarily reccomend it. 13" Lenso's are the ****.
Unless your slammed, or running a 24"+ size slick, you won't have to raise the car up.
kevin7200
Apr 21, 2015 08:34 PM
twilightprotege
Nov 4, 2005 12:57 AM
honda06si
Jul 18, 2005 09:22 PM
honda06si
Feb 20, 2005 09:55 AM
TurboBumblBee
Sep 22, 2004 10:24 PM
