timing belt broke in 85 accord
Old Mar 23, 2005 | 01:04 PM
nyne's Avatar
Default timing belt broke in 85 accord
My timing belt recently broke (about 24 hours after a jiffylube oil change.. just what the doctor ordered.. bleh)
anyway. is the carbureted engine for the 1985 accord hatchback interference or not? would i be okay just replacing the timing belt, or am i going to find a handful of bent valves?
Old Mar 23, 2005 | 01:59 PM
SIMATIC's Avatar
Default Re: timing belt broke in 85 accord (nyne)
not to bust in on ur tred, but if any one knows if a 98 accord ex would also be interference or not?
Old Mar 23, 2005 | 02:56 PM
someone else's Avatar
It Wasn't Me!
The answer to both of you is yes. On the 85 you have a pretty good chance of it being ok, especially if it's an auto. Your car was probably mad at you for letting j-lube touch it. If I remember right all hondas except passport (not a honda anyhow) are interference.
Old Mar 23, 2005 | 03:39 PM
nyne's Avatar
Default Re: timing belt broke in 85 accord (hondasean)
it is an automatic --just my winter car
i hope the car is okay. how can i tell if the valves are screwed? should i just pick up another head from a junkyard or..?
only 83k miles. it is my first honda and i am actually impressed. --makes me want a newer hatch, or a crx haha
Old Mar 24, 2005 | 11:09 AM
James's Avatar
you can test to see if valves are ok by using compression tester. if the compression comes within acceptable range, then the valves are O.K. if it comes in zero, then there is a good chance that you have bent valves.
Old Mar 24, 2005 | 11:33 AM
JimBlake's Avatar
Default Re: timing belt broke in 85 accord (James)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by James &raquo;</TD></TR><TR><TD CLASS="quote">you can test to see if valves are ok by using compression tester...</TD></TR></TABLE>That's true, after you've installed a new timing belt.
If you wanna know NOW, try this...
Spin the crank directly to 90deg away from TDC. Either direction, even backwards. DON'T turn it thru TDC or BDC. Now all pistons are at mid-stroke & you can spin the camshaft all you want.
Check the valve lash. Any bent valves should have valve lash that's way off.
Ashley Akers
Oct 13, 2017 03:39 PM
notoriouskweez
Mar 28, 2011 01:46 PM
AccordInTheMaking
Feb 11, 2010 06:08 AM
im_the_teacher
Nov 15, 2003 11:54 AM
