How to make your R a little bit safer
Well a part of it
For $1.99 I got three of those locks
I thought I would try...
The last thing I need is for someone to ****** it while parked or for the nut/bolt to loosen and shoot the silencer out at a car behind me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RTW Ryan »</TD></TR><TR><TD CLASS="quote">just get the light-up exhaust tip, nobody will want that ****!</TD></TR></TABLE>
You've never been to Milwaukee.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mugen Mike »</TD></TR><TR><TD CLASS="quote">
haha and I dont plan to go
</TD></TR></TABLE>haha and I dont plan to go
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mist sITR »</TD></TR><TR><TD CLASS="quote">just be careful in doesn't rust or get pluged up.
you might wanna cover it with electrical tape or something?</TD></TR></TABLE>
It's made out of brass, no problems with rust
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ITR0952 »</TD></TR><TR><TD CLASS="quote">Why not use a screw instead of a lock?</TD></TR></TABLE>
Reading comprehension > you
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso »</TD></TR><TR><TD CLASS="quote">The last thing I need is for someone to ****** it while parked or for the nut/bolt to loosen and shoot the silencer out at a car behind me
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso »</TD></TR><TR><TD CLASS="quote">It's made out of brass, no problems with rust
The lock itself may be brass, but the metal loop that latches into it only has a rust proof coating on it. I had similar locks, and the cheap metal coating flaked off and began to rust. Also water got inside the lock and it ended up rusting shut. Just a heads up..
</TD></TR></TABLE>The lock itself may be brass, but the metal loop that latches into it only has a rust proof coating on it. I had similar locks, and the cheap metal coating flaked off and began to rust. Also water got inside the lock and it ended up rusting shut. Just a heads up..
c0tdamn, why wasn't this thread made when i still had my silencer??? nut and bolt couldn't hold my shat in, fuggin silencer flew out while driving on the freeway
