Poll: Opinion on which engine would best fit my needs?
Old Mar 23, 2005 | 11:22 AM
1991 DA's Avatar
Default Poll: Opinion on which engine would best fit my needs?
I can't decide on which engine would be best. I'm looking for a dependable daily driver that will give me a little kick when I want it . I'd like this engine to last me a long while, and I probably wouldn't be turbo-ing it for a while. I do not have a very big budget, and am looking to stay under $1000 for EVERYTHING needed to do the swap. VTEC would be nice, and I'm pretty sure I can handle the wiring. I'd like to stick to D-series as well, can't afford any B-series. Sorry it's kind of a big poll, but hey, there's alot of D-series choices .
Old Mar 23, 2005 | 11:42 AM
EJ2-Fluffy's Avatar
Default Re: Poll: Opinion on which engine would best fit my needs? (eightcylinderkiller)
A6 with Z6 head (w/ a mild street cam, using a obd0 to obd1 conversion harness)
- Cheap (heads can be found in good condition for a 100)
- Can use a mild street cam (stage 1, no valve train upgrade)
- D16Y8 manifold or D16Z6, both great manifolds
- 9.95:1 compression (daily driveable)
- Can turbo down the line, but dont recommend it
-Jon
Old Mar 23, 2005 | 11:43 AM
92integra_gs's Avatar
mini-me w/ a z6 head... should get you around $300-$500 (all the parts necessary) and then spend on either P&P or cams... & on some bolt on upgrades...
Old Mar 23, 2005 | 11:59 AM
1991 DA's Avatar
thanks for the info guys!!
Old Mar 23, 2005 | 12:16 PM
ef_you_again's Avatar
go with a b18a its cheap like 500
Old Mar 23, 2005 | 02:16 PM
Malgerus's Avatar
Default Re: (ef_you_again)
The mounts, shift linkage, etc are not though...
Old Mar 23, 2005 | 03:10 PM
CRX Toad's Avatar
https://honda-tech.com/zero...88863 <-----YOU GUYS SHOULD GET TOGETHER!!!!!!!!
Old Mar 23, 2005 | 03:20 PM
PotatoePAPA's Avatar
Default Re: Poll: Opinion on which engine would best fit my needs? (CRX Toad)
jesus christ....
Old Mar 23, 2005 | 03:31 PM
1991 DA's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRX Toad &raquo;</TD></TR><TR><TD CLASS="quote">https://honda-tech.com/zero...88863 &lt;-----YOU GUYS SHOULD GET TOGETHER!!!!!!!!</TD></TR></TABLE>
actually we're asking totally different questions...
Old Mar 23, 2005 | 05:03 PM
FalkenSiR's Avatar
my vote goes to the d15. Same power as an Z6, less work, and dont necessarily have to go obd1.
Old Mar 23, 2005 | 05:09 PM
Targa250R's Avatar
be professional
If it's for a daily driver, you might as well not go crazy on compression so that you can run regular fuel. D16Z6 would be my recommendation.
Old Mar 23, 2005 | 05:18 PM
1991 DA's Avatar
Default Re: Poll: Opinion on which engine would best fit my needs? (fast88std)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fast88std &raquo;</TD></TR><TR><TD CLASS="quote">my vote goes to the d15. Same power as an Z6, less work, and dont necessarily have to go obd1.</TD></TR></TABLE>
Doesn't it have to be obd1 to run VTEC??? and I think d15 has less torque but not sure.
Old Mar 23, 2005 | 05:24 PM
Targa250R's Avatar
be professional
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eightcylinderkiller &raquo;</TD></TR><TR><TD CLASS="quote">
Doesn't it have to be obd1 to run VTEC??? and I think d15 has less torque but not sure.</TD></TR></TABLE>
The D15B VTEC has both less torque and horsepower than a Z6. I see them advertised as having 125-130hp all the time, but that's incorrect - they really only have about 120hp. Not a big difference, but still a difference nonetheless.
And yes, OBD-1 is required to run VTEC properly.
Old Mar 23, 2005 | 05:25 PM
Captian_Honda's Avatar
Default Re: Poll: Opinion on which engine would best fit my needs? (Targa250R)
D's are pretty cheap so get the best ----&gt;D16z6
Old Mar 23, 2005 | 05:45 PM
1991 DA's Avatar
Default Re: Poll: Opinion on which engine would best fit my needs? (Captian_Honda)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Captian_Honda &raquo;</TD></TR><TR><TD CLASS="quote">D's are pretty cheap so get the best ----&gt;D16z6</TD></TR></TABLE> yea i was thinkin just that, especially since z6 is USDM, thus will pass visual inspection and smog when i take it to DMV. Where would you recommend I buy a D16Z6, if I was to get it online and not from a junk yard. I checked HMO and they don't have them and I'd like to get one with everything needed.
Old Mar 23, 2005 | 07:18 PM
1991 DA's Avatar
any more votes???
Old Mar 23, 2005 | 07:59 PM
just get one from the junkyard and rebuild it
Old Mar 24, 2005 | 03:19 PM
crxtreme89h's Avatar
I vote B16 or nothing at all. Whatever you can afford.
tollickj
Engine Management and Tuning
19
Jan 27, 2013 07:03 PM
vxnine
Oct 14, 2004 07:39 PM
katb16vo
Mar 14, 2004 09:41 PM
Honda-Fanatic
Feb 18, 2004 10:02 AM
Honda-Fanatic
Feb 18, 2004 09:30 AM
