Low idle and bad acceleration
Old Mar 23, 2005 | 11:01 AM
Dooley's Avatar
Default Low idle and bad acceleration
Its been like this for a while but I can still drive from point A to point B as long as I'm careful.
My idle after my engine warms up is near 0.. maybe 1/10k rpms. When I first start it its at 1k but goes down.
When ever I acclerate faster than average my engine feels like its stalling.. kinda bucks a little until I left off the gas.
It's really annoying and would like to resolve this situation.
Any help would be great!
Thanks in advance,
-Kevin
Old Mar 23, 2005 | 11:04 AM
POE's Avatar
POE
adjust your idel on your TB. also try ajdusting your FITV right under your TB, search for FITV if u need to see what it looks like or where its at. also is your timing corret?
Old Mar 23, 2005 | 11:13 AM
Dooley's Avatar
my friend adjusted my TB for me.. but within a week it went back to where it was... but I will adjust it again. Dont know what FITV is but I will search, and how would I know if my timing is correct?
Old Mar 23, 2005 | 11:16 AM
POE's Avatar
POE
timing gun, there are several ways, does your buddy who helped u earlier know how? , also the idel adjust is on the TB , your not actually adjustng the TB its a flat tip screw up there. turn it with the car on and see if it helps it out. turn it left to make it idel higher
Old Mar 23, 2005 | 01:04 PM
Catman316's Avatar
Default Re: (POE)
Check ur timing with a timing gun, That can be ur problem
Old Mar 29, 2005 | 11:15 PM
Dooley's Avatar
Default Re: (Catman316)
Okay I replaced all the spark plugs and my car runs fine , but only 95% of the time.
So i am going to replace the wires and plugs and see if it fixes the problem completely.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by POE &raquo;</TD></TR><TR><TD CLASS="quote">actually adjustng the TB its a flat tip screw up there. turn it with the car on and see if it helps it out. turn it left to make it idel higher</TD></TR></TABLE>
I looked at the TB for a whole minute searching in vain but I cant find it . I searched in archives but all the pictures are broken so if someone can take a picture and point it out to me that would be great.
My car still idles at pretty much .1 rpms and at redlights sometimes it feels like its going to stall.
Old Mar 30, 2005 | 12:42 AM
CRacer21's Avatar
Default Re: (aznm3nac3)
Have you thought about fuel pressure? I have the same problems when under acceleration sometimes. Especially up hills, or in a lower part of a gear. Like if I'm in 4th at like 3500 rpm and I punch it it kinda bogs a little.
Old Mar 30, 2005 | 10:24 AM
Dooley's Avatar
Default Re: (CRacer21)
yeah.. that was my first thought.. "fuel pump has gone bad".. but my friend said it was the TPS... but then I replaced the spark plugs and it works alright for now.. but I can feel it slowly getting worse.
Today, When I turned on the AC on HIGH, it started bogging like crazy till i turned it off and gave it a little gas.
Can low idle ruin spark plugs?
Old Mar 30, 2005 | 10:32 AM
IHateJDM's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aznm3nac3 &raquo;</TD></TR><TR><TD CLASS="quote">Can low idle ruin spark plugs?</TD></TR></TABLE>
low idle won't hurt your plugs. did you ever check your timing?
Old Mar 30, 2005 | 10:33 AM
POE's Avatar
POE
the idel screw is a small flat tip, face the opening of your TB and its on that side. the part that opens up.
Old Mar 30, 2005 | 09:05 PM
Dooley's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRacer21 &raquo;</TD></TR><TR><TD CLASS="quote">Have you thought about fuel pressure? I have the same problems when under acceleration sometimes. Especially up hills, or in a lower part of a gear. Like if I'm in 4th at like 3500 rpm and I punch it it kinda bogs a little. </TD></TR></TABLE>
oh yeah.. what did you do to solve your problem, did it seem like your car wanted to stall at stoplights.. my car sounds like it is goign to but doesnt.
Thanks guys for your help.
I'm such a nub at this.
Old Mar 30, 2005 | 09:10 PM
jayzonmyfeet's Avatar
Default Re: Low idle and bad acceleration (aznm3nac3)
my friend had the same problem and it was his distributor
Old Mar 30, 2005 | 10:14 PM
Dooley's Avatar
Default Re: Low idle and bad acceleration (jhmaccp3)
well I just checked all my CEL's.
67: Catalyst system Efficiency Below Threshold malfunctioning or defective catalyst system
73: Cylinder 3 Misfire or a Random Misfire a condition is present that is creating a cylinder misfire
74: Cylinder 4 Misfire or a Random Misfire a condition is present that is creating a cylinder misfire
So searching and reading, figured the best place to start is to buy new wires/caps/rotors. *fingers crossed
The CEL 67 is b/c my exhaust has a huge hole in it from rust APEXI N1
Modified by aznm3nac3 at 7:57 AM 3/31/2005
Modified by aznm3nac3 at 7:58 AM 3/31/2005
Old Mar 31, 2005 | 11:19 AM
Dooley's Avatar
anymore ideas?
Old Mar 31, 2005 | 11:49 AM
IHateJDM's Avatar
spark plugs/plug gap, injector cleaner.
Dylanthoms
Apr 24, 2018 08:52 PM
young_tuner
Feb 6, 2009 10:37 AM
SOHCMAN
May 31, 2005 03:10 PM
B16CRXT
Jul 19, 2004 11:06 AM
Fullthrottlegsr
Jul 16, 2004 09:05 PM
