replacing shocks
Old Mar 23, 2005 | 07:31 AM
rdaggett's Avatar
Default replacing shocks
I have a 94 HB and I am going to get Koni Reds with H&R racing springs .....
I was wondering if I should replace the schock mounts and the should I put dust covers on the piston rods?
anyone ?
Thank you
Old Mar 23, 2005 | 07:38 AM
dohcdelsol's Avatar
Default Re: replacing shocks (rdaggett)
I dont believe you have to replace the piston dust cover.
I would recommend getting the koni yellows for damper adjustibility.
https://honda-tech.com/zerothread?id=1106020
Thats a write up in the suspension forum and the creater did not use the dust cover.
Old Mar 23, 2005 | 08:35 AM
rdaggett's Avatar
Default Re: replacing shocks (dohcdelsol)
i found the koni reds for 300 with free shipping .... didnt want to spend 500 on yellows .... I will be using H&R racing springs and set the reds to 2-3 click on the internal adjustment ..... so that the stiffnes of the H&Rs will do 60% of the work and and shocks 40%
unless you know of a place I can get the yellows for like 400
redDAinteg
May 10, 2005 12:42 AM
ftwlucky13
Suspension & Brakes
21
Apr 5, 2005 01:13 PM
FBP Ex-T
Feb 19, 2002 05:34 PM
StinkyTofu
Aug 24, 2001 10:03 AM
kod311
Aug 23, 2001 11:10 AM
