LSD tranny, do i have 1?
jsut got my jdm b16 swap and i got a y21 tranny wtih it, it still has the half shaft attached to teh tranny. i read on here somewheres if u can look through the tranny and see out the other side with nothing in the way u have lsd. i look through and see the half shaft in there and nothing in the way, does this mean i have LSD? i didnt order it, thats y i ask...
does the y21 tranny code mean anything about LSD?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jL iLLuZiOnz 9 »</TD></TR><TR><TD CLASS="quote">does it look like this?
if it does, you have LSD.</TD></TR></TABLE>
as i said it has the halfshaft still in there but when i look through u see the end of the halfshaft, does anybody have a pic of the tranny hole that isnt LSD?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Targa250R »</TD></TR><TR><TD CLASS="quote">An open diff will have a small pin going across the middle when you look through the diff.</TD></TR></TABLE>
so u could see it running up and down across the hole in the tranny? sweet i think i just got a free LSD y21 tranny, but i would still like a picture of a non LSD tranny hole so i know wha i would be looking for, but i can put my finger in the hole and it barely goes through to the other side before i touch the half shaft spindle
if you can touch the half shaft end with your finger, than it is lsd. A non lsd has a rather large dowel shaped thingy in the center of the two female ends. Flash a light, if there is nothing inside besides the other end of your cv shaft, than consider yourself lucky.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jwbetley »</TD></TR><TR><TD CLASS="quote">if you can touch the half shaft end with your finger, than it is lsd. A non lsd has a rather large dowel shaped thingy in the center of the two female ends. Flash a light, if there is nothing inside besides the other end of your cv shaft, than consider yourself lucky.</TD></TR></TABLE>
thanks i seen no dowel type thing in there, so im guessing its LSD, friggin awsome
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sIcWiTiT »</TD></TR><TR><TD CLASS="quote">just take the half shaft out. it will save you alot of guess work.
peace</TD></TR></TABLE>
i was going to do this but i thought id as on here first cause i knew there was another way to check
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMallTHEway »</TD></TR><TR><TD CLASS="quote">nope.</TD></TR></TABLE>
yup?
yup?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMallTHEway »</TD></TR><TR><TD CLASS="quote">Yup.</TD></TR></TABLE>
yup what foo?
yup what foo?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Reiketsukan »</TD></TR><TR><TD CLASS="quote">When I burn out in my Sol (stock tranny, I think) I always leave 2 black marks...
So am I just getting equal traction, or what?</TD></TR></TABLE>
Yes. Each side is alternating between slip and grip.
Hence the reason that retarded "tests" like burnouts prove nothing.
So am I just getting equal traction, or what?</TD></TR></TABLE> eventually at the end of a burn out u might leave 2 tire marks... but if u see usually one starts b4 the other....with lsd u start spinning both at the same time
Hence the reason that retarded "tests" like burnouts prove nothing.</TD></TR></TABLE>
yeah burnouts prove nothing, except that u hate ur tires y0!
if you have lsd, when u spin ur wheel (physically with ur hands on a lift) they should spin the same way right? where non-lsd would spin opposite...?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SkoundrelUSA »</TD></TR><TR><TD CLASS="quote">if you have lsd, when u spin ur wheel (physically with ur hands on a lift) they should spin the same way right? where non-lsd would spin opposite...?</TD></TR></TABLE>
That "test" doesn't work either. Some LSDs will spin them in the same direction, while other LSDs will spin them in opposite directions like an open diff.
That "test" doesn't work either. Some LSDs will spin them in the same direction, while other LSDs will spin them in opposite directions like an open diff.</TD></TR></TABLE>
so basically the only way to tell is if there is a straight through hole or if there is a bar going across in the tranny? even the turning tires wont tell u?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CRXified »</TD></TR><TR><TD CLASS="quote">so basically the only way to tell is if there is a straight through hole or if there is a bar going across in the tranny? even the turning tires wont tell u?</TD></TR></TABLE>
Right. Just look for the diff pin.
