exhaust noise level question
Old Jan 25, 2002 | 06:34 AM
Greyout's Avatar
Default exhaust noise level question
is exhaust note changed by number of bends? would a pipe with 0 bends (straight) be louder then one with 2 or 3?
Old Jan 25, 2002 | 06:48 AM
SyndicateEH's Avatar
Default Re: exhaust noise level question (JDM LUDE)
I don't believe 0 bends opposed to 3 bends would make much exhaust tone differences.
**not to insult your intelligence see below** wasn't sure if your question was about exhausts in general or straight pipes. ..
The noise level is controlled by the silencer and/or muffler. The silencer if used in a exhaust system is basically a little straight through (you see through both ends)muffler. Same with a staright through muffler - in those mufflers are lil fingers that pull in the flow or noise into the packed canister. There are other mufflers that are not staright through, they has a "S" bend in them. Those are even quieter.
hope that helps..
Old Jan 25, 2002 | 07:20 AM
Greyout's Avatar
Default Re: exhaust noise level question (SyndicateEG)
well to be more specific, I was dreaming up a center-exit exhaust and didn't want to do it if it would be too loud, even with a proper resonator / muffler.
Old Jan 25, 2002 | 07:26 AM
Spade's Avatar
Nope there will be no difference in volume. There might be a very slight difference in performance if you can keep the pipe perfectly strait.
Just make sure you have a decent sized resonator. Most of the strait-through mufflers these days don't muffle so well.
Old Jan 25, 2002 | 04:20 PM
csufweed's Avatar
Default Re: exhaust noise level question (Spade)
20" + will do the trick
muddmonky
Nov 27, 2012 02:53 PM
Octanez
15
May 16, 2012 07:57 AM
IntegraMastaz
May 4, 2006 06:41 PM
import810
Nov 24, 2005 10:23 PM
HondaRacer32
Jan 21, 2004 06:55 PM
