I need a BASE MAP for LSvtec!
i need a base map for uberdata to run on till i seat my rings and bring it to the dyno..
I'm running
b18a1 block
pr3 pistons
stock gsr head
gsr manifold with the butterflies open
any help will be great.. thanks in advance!
I'm running
b18a1 block
pr3 pistons
stock gsr head
wow i dont want to call any names but doesnt uberdata come with a stock GSR bin !???! you have a pretty stock motor man, PR3 pistons net you 11 and change compression you should be fine with a stock ecu even.
well I want to know too, and we could use the stock gsr bin, but if someone had an ls/vtec .bin, wouldn't that be better? my build is stock with ls (pr4 ) pistons and a b16 head. anybody?
there is no base map for a ls/vtec.....thats y its a hybrid and you need to get it tuned or it will never run like it should...
no system can put a base map on a b16/b18 head on a b18 block......find a tuner..and i suggest hondata...
PM "rocket"...tell him your setup...he can burn you a basemap for your setup...just tell him your complete setup, but you have to have hondata, uberdata, etc. or whatever so you can plug the chip in.
Karowinn
Engine Management and Tuning
Mar 18, 2019 03:48 PM
MOVE OVER
Nov 13, 2007 09:01 PM
