destroking b16--> 1.5liter b16
Old Mar 23, 2005 | 05:36 AM
ceLtic's Avatar
N/A wh0re!
Default destroking b16--> 1.5liter b16
im feeling pretty sick, so dont mind me.
what are the benefits of sleeving a b16 to maybe something like a 1.5 or 1.4 liter that could probably rev out to 10k-11k rpms?
most people stroke a motor to gain torque through out the powerband, but destroking would do what to an already small displacement motor?
would destroking a b16 to handle even higher revs and very aggressive cams make it better for road racing, or would it be better to have a larger stroke for torque?
i brought up this idea because they sleeved a b16 down to a 1.5 liter and threw it into a newer style civic with coil packs and i was wondering what you guys have to think/say.
discuss.
Old Mar 23, 2005 | 06:19 AM
nickG's Avatar
Default Re: destroking b16--> 1.5liter b16 (ceLtic)
resleeving a b16 to be smaller would be pointless as it would still have the same r/s ratio. so if you found a smaller bseries crank, which i dont think there is, then you could rev it higher.
but that being said, the b16 is still good to rev high, so it would be a pointless waste of money to get even less torque than a b16 already has...
Old Mar 23, 2005 | 07:22 AM
JDogg's Avatar
Default Re: destroking b16--> 1.5liter b16 (nickgmiller0408)
they did that b/c that engine has to survive at 10-11000+ rpm for very long periods of time, they have to run flat out for several minutes.. and do it alot. chances are you wont be reving 12000 rpms steady for 5mins at WOT
Old Mar 23, 2005 | 09:16 AM
per4mance's Avatar
Default Re: destroking b16--> 1.5liter b16 (JDogg)
they also went down to 1.5 liters because the class they are in requires the motor be no bigger then 1.5 liters so thats why they did it, If you recall the supercharged b16 car that goes over 200 mph is also a 1.5 liter. its all in the classes.
Old Mar 23, 2005 | 12:13 PM
ceLtic's Avatar
N/A wh0re!
Default Re: destroking b16--> 1.5liter b16 (per4mance)
awesome. i didnt have the magazine and was wondering why they did that.
thanks
Old Mar 23, 2005 | 02:02 PM
B-twentyVTEC's Avatar
wow.. I've never seen nore heard about DeStroking a B16...
Old Mar 23, 2005 | 03:23 PM
mrbsponge's Avatar
all lisa kubos drag motors were de-stroked gsR's, and were made to 1.6 liters, this is mostly done on forced induction cars because of the lack of torque
Old Mar 23, 2005 | 03:28 PM
96MidoriHatch's Avatar
*edit*
someone beat me to it
Old Mar 23, 2005 | 04:15 PM
swifty4u's Avatar
Default Re: (mrbsponge)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrbsponge &raquo;</TD></TR><TR><TD CLASS="quote">all lisa kubos drag motors were de-stroked gsR's, and were made to 1.6 liters, this is mostly done on forced induction cars because of the lack of torque</TD></TR></TABLE>
Now wouldn't you want torque? Or would they just want higher end power?
Old Mar 23, 2005 | 08:15 PM
rjay8604's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nickgmiller0408 &raquo;</TD></TR><TR><TD CLASS="quote">resleeving a b16 to be smaller would be pointless as it would still have the same r/s ratio. so if you found a smaller bseries crank, which i dont think there is, then you could rev it higher.
but that being said, the b16 is still good to rev high, so it would be a pointless waste of money to get even less torque than a b16 already has...</TD></TR></TABLE>
good job nick, i guess you haven't lost touch yet.
Old Mar 23, 2005 | 08:23 PM
mrbsponge's Avatar
i think the turbo b16 the kubos used was like a 12,xxx rpms motor, and pretty much if it fell out of boost was useless, she even said it wasnt **** till 3rd gear
Old Mar 24, 2005 | 02:44 AM
StorminMatt's Avatar
Actually, the only reason for destroking a FI motor (other than increased rev capacity) would be to reduce side loading under high boost.
Old Mar 24, 2005 | 09:09 AM
BryanPendleton's Avatar
destroking would allow you to run more compression height, improving strenght and durability of pistons and rings, as well as piston stability.
hatchy69
Jun 5, 2007 08:40 AM
E dwinbon G
Jan 9, 2003 10:02 AM
blazin
Aug 27, 2002 08:13 PM
