longer wheel studs and source of the same
Old Jan 25, 2002 | 06:21 AM
four27's Avatar
Default longer wheel studs and source of the same
I searched high and low for longer studs becasue I run spacers and just for safety. ARP has some 12mm x 2.5 inches that are for GM cars and they are great. Honda/Acura lug nuts fit right on them The knurled part is a fraction to big but just run your grinder around the splines a tad bit just to take the tops off them. Cost is about 2.50 each. The old ones at least on the rear knock out with a brass hammar and then you can pull the new ones in with a lug nut. No need to take off the hub and use a press. Expierment with the amount you grind off on one of them. the longer studs will go in the back wheels without taking anything but the wheel off if you have the backing plates off. the front ones require removing the hub but that is a no brainer. Hope this saves someone some grief.
Old Jan 25, 2002 | 06:52 AM
Mike K's Avatar
Default Re: longer wheel studs and source of the same (four27)
Aren't longer studs for slicks in the front? I've never heard of running longer studs in the rear. Hmmm...
Old Jan 25, 2002 | 06:55 AM
davew's Avatar
Default Re: longer wheel studs and source of the same (Mike K)
Morosso also makes nice ones that fit right in w/o grinding.
Mike, roadracers use longer ones in the rear for safety w/ certain wheels, etc...many class rules require a certain amount of thread to be showing through open lugs.
-dave w
Old Jan 25, 2002 | 02:57 PM
four27's Avatar
I am trying to replace them all the way around because I have spacers in there and Moroso said they didnt make them
Old Jan 25, 2002 | 06:39 PM
C-speed's Avatar
We use H&R studs.. about $1.50 each.
Old Jan 25, 2002 | 07:17 PM
four27's Avatar
Default Re: longer wheel studs and source of the same (G3-TEG)
thanks for tip but how do I find H and R? Bellingham is great place. My uncle once owned 1400 feet on Lake Whatcom and County I think bought it for a park.
ricehead
Nov 18, 2009 05:41 PM
Kenzo206
10
Mar 23, 2009 10:05 PM
Cro-Mag
Jan 16, 2003 09:22 PM
EKFerioHawaii
Oct 2, 2002 02:08 PM
dynamo
Sep 20, 2002 11:37 AM
