What size fuel pump for my setup?
My car is 10 years old and it's getting a nice transplant. My question is, what size fuel pump do I need?
B18c1 w/LS crank
Compression ~11.5
Probably run somewhere around 200-220whp.
Even if I don't need an upgraded fuel pump, I'd like to swap this out, so suggestions please. If I don't need a more powerful fuel pump, should I stick with stock or go with walbro?
B18c1 w/LS crank
Compression ~11.5
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SpdFrk »</TD></TR><TR><TD CLASS="quote">You'll need a bigger pump. A walbro 190lph will do but i'd get a 255lph.</TD></TR></TABLE>
Can I just swap out my OEM pump for a higher flow pump... or do I need to buy an FPR or something to go along with it?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Takumi Fujiwara »</TD></TR><TR><TD CLASS="quote">Can I just swap out my OEM pump for a higher flow pump... or do I need to buy an FPR or something to go along with it?</TD></TR></TABLE>
A stock integra/civic fuel pump should be fine.
If you do go aftermarket, go with a 190lph for an n/a setup under 250 whp
high_octane
Apr 25, 2007 06:27 AM
