How to lock the rear wheels of CRX for burnout
Old Mar 22, 2005 | 11:20 PM
Rage Cayman's Avatar
Default How to lock the rear wheels of CRX for burnout
I races a crx with only 358 WHP and I can not recall a good burnout to heat the slicks up enough. I would like some info also picture of a brake system to lock the rear wheels. I have to roll forward the quickly put it in 1st gear to get a bit of burnout on the slicks.After i launches when ever the car get in 3rd gear the slicks starts to slip like hell no traction whatsoever. Please for some info ,pictures would be appreciated. I know i could maybe pull a 1.5 60ft instead of 1.8 60ft.
Old Mar 22, 2005 | 11:24 PM
JL's Avatar
JL
Default Re: How to lock the rear wheels of CRX for burnout (turbocrx1.6l)
you're from the cayman islands? is that your car in the avatar?
what size slicks are you running?
Old Mar 22, 2005 | 11:28 PM
Default Re: How to lock the rear wheels of CRX for burnout (JL)
Iam running 24.5 x 9 13"
Old Mar 23, 2005 | 08:45 AM
black_EM1's Avatar
Community Builder
Community Influencer
E-brake
Old Mar 23, 2005 | 09:03 AM
CHEETAH's Avatar
adjust your handbrake locking spring all the way (you'll know its adjusted when its really hard to pull up).
Sometimes you can also be dragging the rear wheels where they dont spin ... so ask someone to look at it from outside when you do a burnout.
greg
Old Mar 23, 2005 | 12:33 PM
*Boostwerks*'s Avatar
I had this same problem. No matter how hard I pulled the E-brake I always ended up rolling through the burnout.
I'm gonna do the brakes before this season, and see how that helps.
Old Mar 23, 2005 | 12:49 PM
JL's Avatar
JL
Default Re: (Bryson)
do they actually roll or just slide?
you could always employ some watchers to hold the car back.. i think i remember the pacman brothers k20 crx with a tow strap attached to the back with a few people holding on tight, looked like a tug-o-war
Old Mar 23, 2005 | 01:12 PM
Default Re: (JL)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JL &raquo;</TD></TR><TR><TD CLASS="quote">do they actually roll or just slide?
you could always employ some watchers to hold the car back.. i think i remember the pacman brothers k20 crx with a tow strap attached to the back with a few people holding on tight, looked like a tug-o-war </TD></TR></TABLE>
I'm not sure...but I'd be willing to bet it was rolling. I havn't done the rear brakes in the last 4 years.
Old Mar 23, 2005 | 01:28 PM
It rolls.It got the better of me on a track day that I became so frustrated that I would not drive the car for the rest of the day. I have spent so much money at local shops on adjusting e-brakes,change disc pads,callipers. Still not been satisfied by non of thelocal shops who they all claim to be the best brakes shop.
Old Mar 23, 2005 | 01:39 PM
4piston's Avatar
Default Re: (turbocrx1.6l)
Try 2nd gear. It doesn't take a whole lot to heat up the tires. I see a lot of guys holding it there just burning off good rubber.
What kind of clutch do you have? What brand of tires and are they in good shape?
Old Mar 23, 2005 | 03:50 PM
Default Re: (4piston)
I uses the tilton twin disc clutch
Old Mar 23, 2005 | 08:48 PM
Antilag's Avatar
you building boost at the line? It helps, also you need to do your burnouts in 2nd not first. Get a line lock , this will not only help you burnout better but put a load on your axles, tranny before you release the clutch, this will save future breakage to your axles and tranny.
Old Mar 24, 2005 | 01:29 PM
Default Re: (9sech22civic)
Can you send me a picture of a line lock and where can I purchase one?
Old Mar 24, 2005 | 01:45 PM
94twinv-tec's Avatar
I would like to know where I could get one too. I am planning to on putting a t3/t4 turbo on my 94 GSR this summer, I could use one.
Old Mar 24, 2005 | 01:52 PM
Antilag's Avatar
Default Re: (94twinv-tec)
Yes Call and talk to Joe Housley from add it to your toys. He can explain and set you guys up with one. I think he can get a Hurst line lock which will be fine. The number is 1-801-569-1300.
Old Mar 24, 2005 | 01:56 PM
Antilag's Avatar
The Original Hurst Roll Control #HUR174-5000
"The Original HURST Roll Control - Used primarily in Drag Racing to provide positive locking of the front wheels to reduce the chance of rolling through the lights and also to allow for more effective burn-outs. Rigorous testing has proved a 1/100,000 of a second release time and vibration tests have seen up to 30 G's applied without mechanical failure, Adaptable to most domestic and import hydraulic brake systems. Features include - An advanced quality design stainless steel valve assembly for ultimate corrosion resistance, Fully enclosed epoxy molded electrical coil for reliability, Attractive finned aluminum housing to help dissipate heat, Wider lightweight base which provides better mounting stability, Field serviceable unit for cleaning and rebuilding, Complete kite which includes the solenoid valve, snap-action switch, indicator light, fuse, mounting screws and installation instructions. 2For 12-volt negative ground systems only!3 CAUTION - The HURST Roll Control should not be used as an emergency brake or any application requiring the solenoid to be activated for a long period of time."
Details
Old Mar 24, 2005 | 06:02 PM
Thanks alot 9sech22civic.
Old Mar 24, 2005 | 06:50 PM
Antilag's Avatar
no problem, good luck.
Aidroos
Honda CR-V & Element
Oct 7, 2017 03:48 PM
mr.jamrock
Jun 30, 2009 08:21 PM
kcari
Suspension & Brakes
10
Aug 26, 2008 12:55 PM
cambodian
May 29, 2004 04:14 PM
dmotoguy
Feb 24, 2004 09:13 PM
