will springs for 90-93 integra fit crx?
Old Mar 22, 2005 | 11:00 PM
ef_you_again's Avatar
Default will springs for 90-93 integra fit crx?
Old Mar 22, 2005 | 11:34 PM
well ??
Old Mar 22, 2005 | 11:41 PM
Magnum000's Avatar
Default Re: will springs for 90-93 integra fit crx? (ef_you_again)
Yes they will but will set the front end up high, I am speaking from experience!!! If you cut a coil & a-half they will set right!! Otherwise they are too much tall!!!! And I had used the Integra springs with a B16 installed in my CRX!!!!
Old Mar 23, 2005 | 04:22 AM
kaoss_11's Avatar
B A N N E D
They are meant for a heavier car
Old Mar 23, 2005 | 11:26 AM
if its a 1.75 drop how much would it be on my crx
Old Mar 23, 2005 | 03:34 PM
ptoledo's Avatar
Default Re: (ef_you_again)
My friend put neuspeed springs from an integra into a crx, and the car was the same height.
Just some advice. Dont waste your time cutting the spring. Do it right and get the correct springs
Old Mar 23, 2005 | 04:06 PM
Slow ass EF's Avatar
Default Re: (StreetFameDB8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by StreetFameDB8 &raquo;</TD></TR><TR><TD CLASS="quote">Just some advice. Dont waste your time cutting the spring. Do it right and get the correct springs </TD></TR></TABLE>
Old Mar 23, 2005 | 06:03 PM
sideeffects's Avatar
if you plan to do a swap in your car will with springs sag?
Old Mar 23, 2005 | 06:04 PM
kulangot's Avatar
x2
Old Mar 23, 2005 | 06:50 PM
crxbust's Avatar
yes they can fit...... but why go stock? go with ground conrols coil overs with tein 16 way agustable shocks......
jspecPR26
Jun 23, 2005 05:23 PM
youngwon22
Oct 15, 2003 08:54 AM
Turbo Powa
Sep 16, 2003 04:56 AM
Flamenco-T
Jul 21, 2002 01:36 PM
