B16A in an EK.. which AC hose?
Old Mar 22, 2005 | 09:45 PM
2point2's Avatar
Default B16A in an EK.. which AC hose?
which AC hose will fit this setup properly? it's a 98 EK.
Old Mar 22, 2005 | 09:53 PM
b 1 6 a 2's Avatar
What a/c lines and what compressor are you using?? That thing looks heella .
Get the a/c line off a 99-00 si and use the b16 compressor. I know theres other ways to doing this also.
Old Mar 22, 2005 | 10:23 PM
D50boy's Avatar
Default Re: ([civic])
yep you need the hose from a 99-00 SI
Old Mar 22, 2005 | 10:28 PM
RCautoworks's Avatar
Default Re: (D50boy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D50boy &raquo;</TD></TR><TR><TD CLASS="quote">yep you need the hose from a 99-00 SI</TD></TR></TABLE>
But your also gonna need the same compressor, if you got a different type of compressor the lines won't line up, they need to be turned basically.
Old Mar 23, 2005 | 06:38 AM
JayDM_EK9's Avatar
Default Re: B16A in an EK.. which AC hose? (2point2)
what kind of compressure are u using,
Old Mar 25, 2005 | 11:26 AM
D50boy's Avatar
Default Re: (90blackcrx)
I'm sure he is already using the 99-00 Si compressor. A D-series compressor wouldnt bolt up.... would it?
Old Mar 25, 2005 | 11:33 AM
RedDC5's Avatar
No, Id doubt it, but Im not sure.
Old Mar 25, 2005 | 11:40 AM
2point2's Avatar
he's got a 99 si compressor and braket as far as i know;.. so i guess the matching hose will work?
Old Mar 25, 2005 | 11:46 AM
Petah's Avatar
Default Re: (2point2)
B16 compressor --&gt; B16 hoses
D16 compressor --&gt; D16 hoses
You cannot cross match D16 hoses with B16 a compressor or vice versa. However, you can get a del sol vtec P54 lower engine mount which enables you to bolt the D16 compressor onto a B series engine.
Old Mar 25, 2005 | 11:47 AM
2point2's Avatar
Default Re: (Petah)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Petah &raquo;</TD></TR><TR><TD CLASS="quote">B16 compressor --&gt; B16 hoses
You cannot cross match D16 hoses with B16 a compressor or vice versa. However, you can get a del sol vtec P54 lower engine mount which enables you to bolt the D16 compressor onto a B series engine.</TD></TR></TABLE>
that you for knowing your ****.
blkgsr03
Apr 3, 2007 12:35 AM
Duncan90si
Mar 23, 2007 06:02 AM
Sl0wEK
Dec 5, 2004 06:50 PM
