93 eg mounts! b16a2 HELP NOW!
Old Mar 22, 2005 | 07:53 PM
athoughts's Avatar
Default 93 eg mounts! b16a2 HELP NOW!
The problem lies in the lower tranny mount(rear mount), whatever the *** it is..
i CAN NOT get it aligned!
this is in a 93 couple with a b16a2. '00 si tranny ..
Before, ive had this mount bolted up with 2 bolts instead of the 4, because they would not align, they are off by like hair, but enouph to not go in!
but the other night i broke my tranny casing, the lower bolt snaped out of the casing leaving me with no choise other then to get it fully in!
here are some pictures, my whole motor is held up by a jack right now, trying to push and force it in...
hanging motor..
under the car
Old Mar 22, 2005 | 07:59 PM
r3dh4tch's Avatar
Default Re: 93 eg mounts! b16a2 HELP NOW! (athoughts)
are you using a rear transmission bracket off of a 94+ integra? if not, try that... that's what i am using and everything is flawless. also... what mounts are you using on the engine (right and left side)?
Old Mar 22, 2005 | 08:09 PM
HATCHingMN's Avatar
you get the wrong mount,..99-00 si rear mount wont work on EG
you will need the mount from an integra 94-up
Old Mar 22, 2005 | 08:14 PM
athoughts's Avatar
Default Re: 93 eg mounts! b16a2 HELP NOW! (HATCHingMN)
yeah i just talked to some guys on the phone about it, and i think that is the problem, im not using the integra mount..
i had weapon r's on the right and left but now just on the right cause the left broke last weekend, and i had to put a stock one in
thanks!
Electron Eg
Nov 15, 2008 11:58 PM
caymanjdm97dc2
Dec 29, 2006 12:39 PM
blocburner1
Jun 27, 2005 05:35 PM
athoughts
13
Mar 27, 2005 07:25 PM
Del_Slowest
Jan 18, 2005 10:50 AM
