Type R Candy (SRS reset instructions, *PIC*)
Old Mar 22, 2005 | 07:37 PM
IGGY's Avatar
Default Type R Candy (SRS reset instructions, *PIC*)
After looking more through my archives I came across this pic. I could not find it any where online. All of the places that had it before had either removed it or the sites are no more.
So for you I deliver!
http://www.norcalrcrew.com/index.php?categoryid=13
Old Mar 22, 2005 | 07:44 PM
Chris F's Avatar
Default Re: Type R Candy (IGGY)
"do not use a jumper wire."
Does that mean, use a jumper wire?
Old Mar 22, 2005 | 07:51 PM
IGGY's Avatar
Default Re: Type R Candy (Chris F)
Yes, that is correct. The service connector is not referred to as a "jumper wire", a jumper wire would be a paper clip or some sort of shorting device.
Old Mar 22, 2005 | 08:15 PM
Big Phat R's Avatar
So this erases the memory of something?
Or just makes the light go off if you have removed the airbags?
:confused:
Old Mar 22, 2005 | 08:20 PM
RTW DC2R's Avatar
is this only for SRS codes, or all codes in memory? I wish there was a way to remove the immobilizer CEL and keep it off. And I usually just use a paper clip as a jumper wire
Old Mar 22, 2005 | 08:28 PM
B2FiNiTY's Avatar
WOW! that easy!?
Old Mar 22, 2005 | 09:04 PM
IGGY's Avatar
Default Re: Type R Candy (B2FiNiTY)
Yeah that resets the SRS unit.
From what I understand, when you remove your wheel for an aftermarket one, you get the SRS light to stay on. Even if you put the stock steering wheel back on the light won't go away unless you reset the system. Hence the pic.
Now if you ad a 2.2ohm resistor to the SRS plug and perform the function, VUALLA, no SRS light, and you don't go throught the trouble of pulling out the bulb.
Old Mar 23, 2005 | 03:55 AM
.RJ's Avatar
.RJ
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Chris F &raquo;</TD></TR><TR><TD CLASS="quote">"do not use a jumper wire."
Wrong.
I reset mine with a paper clip after re-installing the stock wheel. Easy to do once i figured it out. Helms ownz.
Old Mar 23, 2005 | 05:35 AM
Dan GSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">WOW! that easy!? </TD></TR></TABLE>
not really, **** is a PITA
took me a bunch of tries
Old Mar 23, 2005 | 05:38 AM
.RJ's Avatar
.RJ
Default Re: Type R Candy (Dan GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Dan GSR &raquo;</TD></TR><TR><TD CLASS="quote">
You suck?
Old Mar 23, 2005 | 05:40 AM
Dan GSR's Avatar
Default Re: Type R Candy (.RJ)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">
You suck? </TD></TR></TABLE>
You swallow
Old Mar 23, 2005 | 10:47 AM
IGGY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .RJ &raquo;</TD></TR><TR><TD CLASS="quote">Wrong.
I reset mine with a paper clip after re-installing the stock wheel. Easy to do once i figured it out. Helms ownz.</TD></TR></TABLE>
It just says not to. It doesn't mean you can't do it.
Old Mar 23, 2005 | 11:13 AM
youngvedder's Avatar
im gonna try this tonight....hate having that light on!
Yv
Old Mar 23, 2005 | 12:54 PM
IGGY's Avatar
Default Re: Type R Candy (youngvedder)
Don't forget to use a 2.2ohm resistor. The resistor simulates the air bag so the light won't come back on.
Old Mar 23, 2005 | 12:57 PM
Todd00's Avatar
I said I don't want a title!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IGGY &raquo;</TD></TR><TR><TD CLASS="quote">Don't forget to use a 2.2ohm resistor. The resistor simulates the air bag so the light won't come back on.</TD></TR></TABLE>
Where do you stick the resistor at? Where you'd put the jumper?
Old Mar 23, 2005 | 01:16 PM
.RJ's Avatar
.RJ
Default Re: Type R Candy (Todd00)
The jumper goes in the SRS MEM plug in the underdash fuse box. Remove the plug to jumper it.
Old Mar 23, 2005 | 01:59 PM
IGGY's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Todd00 &raquo;</TD></TR><TR><TD CLASS="quote">Where do you stick the resistor at?</TD></TR></TABLE>
The resistor had to connect the two wires that plug into the yellow SRS harness.
Old Mar 23, 2005 | 02:19 PM
Stinkycheezmonky's Avatar
Suspetise...
I just took my bulb out, wasn't all that difficult.
Old Mar 23, 2005 | 03:06 PM
IGGY's Avatar
Default Re: Type R Candy (sscguy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sscguy &raquo;</TD></TR><TR><TD CLASS="quote">I just took my bulb out, wasn't all that difficult. </TD></TR></TABLE>
That works too, but if you still have the passanger airbag and would like to have it operational, although there are rumors that it may still work, this is what you have to do.
Old Mar 23, 2005 | 05:47 PM
Suspetise...
Ah, good point. I don't have a passenger airbag in my hatch, so that thought never even occurred to me.
Old Mar 23, 2005 | 09:21 PM
j0hn-0h's Avatar
i'm confused also where is the scs connector located on a 2000 dx hatchback? and do i just connect it to the airbag connector? i'm trying to install my stock one back on and the guy who took of my stock steering wheel cut some wires =/ thanks for the help
Old Mar 23, 2005 | 10:14 PM
IGGY's Avatar
Default Re: Type R Candy (amsohcvtec)
I don't have pics of the SRS cables handy, however the picture is clearly understandable if you have an Integra. I would not know where it is in a 2000 DX.
Old Mar 24, 2005 | 12:22 PM
JOHN WAYNE's Avatar
its in the same spot on the civic fusebox...i think the fuseboxes might be identical
Old Mar 24, 2005 | 12:23 PM
j0hn-0h's Avatar
ehh thanks anywayz i will be trying to fix my srs problem hopefully everything works out
Old Mar 24, 2005 | 01:07 PM
j0hn-0h's Avatar
i'm currently trying to reset my srs sign and i found the mes but couldn't find the scs anyhelp would be appreciated thanks
