Fastbrakes any good?
Old Jan 25, 2002 | 02:10 AM
Duck Sauce's Avatar
Default Fastbrakes any good?
Those with FastBrakes, what are you thoughts on this system. They are pretty inexpensive, but then again you get what you pay for. Any complaints? How's the fitment? Do the brakes make that annoying squeeling sound when you brake? TIA
Old Jan 25, 2002 | 03:32 AM
jg's Avatar
jg
Default Re: Fastbrakes any good? (www.s4-mtm.com)
if you're speaking of the Wilwood kit Brian(Fastbrakes) offers, I have a similar kit on my car. Brian's was out at the time. No squealing-that depends on your pads/shims/backing. Works great coupled with his "big rear brakes" kit. You didn't specify what you were speaking of. Hope this helps...
Old Jan 25, 2002 | 03:41 AM
Willard's Avatar
can you buy rotors at Autozone/Pepboys?
Will
Old Jan 25, 2002 | 05:02 AM
People_Mover's Avatar
From: HT PRO POKER PLAYER IM FOR FREE STARTUP, MONEY
Default Re: Fastbrakes any good? (Willard)
my friend has the fastbrakes kit on his GSR and it stops faster than my R
Old Jan 25, 2002 | 07:09 AM
onyx00's Avatar
Default Re: Fastbrakes any good? (RealTypeR)
I am going to hopefully go take a look at the kit soon since I am in Arizona. I will let everyone know more about the kit once I see it.
Old Jan 25, 2002 | 07:38 AM
BoM's Avatar
BoM
Default Re: Fastbrakes any good? (onyx00)
i like the 11inch 4piston caliper upgrade. front and upgraded rear rotor.
PRICE is
Old Jan 25, 2002 | 07:49 AM
IN VTEC's Avatar
If you get the kit, you'll probably wanna stick with the 11" rotor / 4-piston Wilwood caliper kit. I think you can save a couple of pounds per corner of unsprung weight using this setup. This setup was tested to fit under the stock 15" '95 GS-R rims.
There's also a 12" Wilwood kit, but it doesn't fit under the stock 15" rims.
I'd e-mail Brian < fastbrake@hotmail.com > for specifics, like weight reduction, and whether it uses a 2-piece or 1-piece rotor, pricing, and the info on what modifications (if any) need to be made for it to fit properly. maybe you could have him e-mail you a copy of the installation instructions for the kit you want.
Old Jan 25, 2002 | 08:49 AM
junglistgsr's Avatar
Default Re: Fastbrakes any good? (IN VTEC)
i have the ITR spec setup on the front and the rear 11.4" and im very happy with brian and his setup....
my rear rotor:
Old Jan 25, 2002 | 08:52 AM
B2FiNiTY's Avatar
I've only heard good things.
Old Jan 25, 2002 | 09:03 AM
owen_the_soyboy's Avatar
Default Re: Fastbrakes any good? (B2FiNiTY)
I have a GSR but went with the 11" 2 piece front rotor with ITR calipers, then also added the 11.4" rear rotor upgrade.
fit was great, install was quick, performance for price is phenominal
I cant wait to get the 4 piston Wilwoods for my car now! just have to save up...
Old Jan 25, 2002 | 09:17 AM
chiangm's Avatar
here is a pic of wilwood brake kit i got from brian.
http://www.vtec.tv/civic/marvin/misc/fastbrakes.jpg
Old Jan 25, 2002 | 09:50 AM
B( * Y * )BIES's Avatar
Default Re: Fastbrakes any good? (chiangm)
junglistgsr - Nice rear rotor you got there buddy! drop me an emial sometime
Fastbrakes has great stuff and at great prices!
NO SPOON calipers like most all would like to have, but for function and cost you do get a nice set up that performs better than stock! (at least on my Si it did)
Old Jan 26, 2002 | 06:23 AM
IN VTEC's Avatar
Default Re: Fastbrakes any good? (owen_the_soyboy)
I should have gone with the 4pot Wilwood setup in the front (instead of the Accord V6 calipers) b/c I had quite a bit of clearance issues with the caliper bracket and brake pad retaining clips.
For the first week, the scraping was unbearable and I ended up taking it apart 3 times to take more of the bracket material and retainer material off each time. I don't think it's so bad now, but I should have spent the extra $400 to make life that much easier for me.
I think I spent a total of 8 hours just on filing & dremeling the caliper bracket, and then checking the clearances with some anti-seize compound smudged on the rotor.
Old Jan 26, 2002 | 07:55 AM
Erik_Pb_Foot's Avatar
New User
How much do the Fastbrakes cost? Keep in my I don't have an R, if that makes a difference. Do they have a website?
Old Jan 26, 2002 | 07:56 AM
Dirty GS-R's Avatar
New User
Default Re: Fastbrakes any good? (Pb_Foot)
http://www.fastbrakes.com
Old Jan 26, 2002 | 08:04 AM
New User
Default Re: Fastbrakes any good? (2K1 GS-R)
Thanks!
Old Jan 26, 2002 | 08:35 AM
StinkyTofu's Avatar
whoa this is pretty cool! Those willwood calipers look pretty sweet. The whole 4-piston kit is only 600 bucks? Does that mean i could have stopping power equivalent to the ITR withOUT getting the 5-lug conversion?
Old Jan 26, 2002 | 12:29 PM
TodaSi's Avatar
Default Re: Fastbrakes any good? (B-18C1)
Hell yes! Brian is great and Fastbrakes is great!
Old Jan 29, 2002 | 04:33 AM
Default Re: Fastbrakes any good? (TodaSi)
WORD!
Old Jan 29, 2002 | 05:11 AM
Trey's Avatar
25 Year Member
Default Re: Fastbrakes any good? (99Si-R)
I've had both the 11" upgrade and the Wilwood 11" upgrade.
Both were excellent quality and it took no time to install them.
Brian is a first rate guy and will make sure you are satisfied.
Here is my current setup and I'm very happy!!!!
Old Jan 29, 2002 | 06:04 AM
rambler's Avatar
New User
Default Re: Fastbrakes any good? (Trey)
What size pads does the willwood take?
ITR size?
Old Jan 29, 2002 | 07:21 AM
GQ 05YellowEVO8's Avatar
Default Re: Fastbrakes any good? (rambler)
Would the 11.75" kit be better than the 11" kit? I'd get either of the two with the 4 piston wilwoods... lemme know
Old Jan 29, 2002 | 07:56 AM
SkyeC's Avatar
Boba Connoisseur
25 Year Member
ITR size?
Big surprise here, but they take Wilwood Dynalite sized pads. *boggle*
Old Jan 29, 2002 | 08:06 AM
rambler's Avatar
New User
Default Re: Fastbrakes any good? (SkyeC)
Thanks Skye! I just know there are some out there that use ITR pads. Wondered if this was one of them.
Old Jan 29, 2002 | 09:21 AM
White Dragon's Avatar
Default Re: Fastbrakes any good? (junglistgsr)
my rear rotor:
Am I correcting in saying that this rear rotor will fit behind the stock rims, and uses the stock rear calipr? Also, do you sacrifice anything when doing this? Does the e-brake still work?
