sohc zc question...pics inside
Old Mar 22, 2005 | 05:47 PM
ZCHF's Avatar
Default sohc zc question...pics inside
I'm trying to install a sohc zc but it came carbuerated and I need to take off all the carb stuff and change it to intake mani stuff. In the pic below, What is the large oil gap next to the right most intake port and also do I need the water rail that runs below it?
thanks
brian
Old Mar 22, 2005 | 06:21 PM
ZCHF's Avatar
Default Re: sohc zc question...pics inside (ZCHF)
anyone???
Old Mar 22, 2005 | 06:40 PM
jlicrx's Avatar
the hole to the right side of the intake ports is where the fuel pump was on the carbed engine - you need to make a block-off plate out of 1/8" aluminum with 2 holes in it - silicone it up and bolt it on - water rail? are you meaning the pipe that runs to the thermostat housing? you need to leave that - it comes from the water pump
Old Mar 22, 2005 | 06:46 PM
ZCHF's Avatar
Default Re: sohc zc question...pics inside (jlicrx)
Thanks, Ive heard about that oil pump thing, and now I know to block it off. what I meant about the water rail was the one inch pipe that runs beneath all the intake ports and has the grapefruit size housing at the far bottom right of the picture. This is the thermo housing and Im going to retain it?
Thanks for the help, Im asking all these questions because the motor it is replacing is a dohc zc and im not sure the similiarities
thanks again
brian
Old Mar 22, 2005 | 07:01 PM
Exempt's Avatar
Yes, u need to keep the thermostat housing...
Question, is that a SOHC ZC with VTEC? If not, why are u going from DOHC ZC to SOHC ZC?
Just asking, because if thats the SOHC ZC with VTEC, the hole right next to the last intake hole would be the VTEC solenoid if Im not mistaken... Not sure if thats the hole u meant or not tho...
Old Mar 22, 2005 | 07:06 PM
ZCHF's Avatar
Default Re: sohc zc question...pics inside (Exempt)
no vtec....legality issues. I was always scared of getting pulled over with the dohc zc. funny thing is im probably going to turbo this motor, and I will be in the same boat. oh yeah, the dohc zc broke a timing belt too. that played a large part
Old Mar 22, 2005 | 07:10 PM
Exempt's Avatar
Yea, that will do it... hehe
Good luck with the swap tho!
Old Mar 22, 2005 | 07:50 PM
ServiceAdvisor's Avatar
I've got an old D15b chillen at my house with the block off plate already there, Its your as long as you pick it up, I'm in So Cal so I'm not outrageously far. - Darrell
Old Mar 22, 2005 | 09:01 PM
enkeiteg's Avatar
actually you need to take that rear water tube off of that single cam motor because it had the carbs on it...
and you have 2 outlets on that rear tube. Well you only need one so i would take the rear water tube off your dohc zc and put it on your sohc zc. That extra nipple by the waterpump is for heating the carbs...which you dont have!!!
the mpfi only has 1 nipple on the back water tube. Just thought id help you out a bit (dont ask how i know)
Old Mar 23, 2005 | 06:36 AM
ZCHF's Avatar
Default Re: (saturn)
Thanks guys!!!!
I appreciate all the help. I still have to take out the dohc zc, so when I do that I might have more questions, but for the time being, I dont have anymore questions. Thanks again guys
Brian
ef_hatchback
Mar 22, 2013 06:40 AM
Red_ED8
11
Nov 28, 2010 09:40 AM
mr2passat801
Nov 4, 2010 08:48 PM
brownsEF
Mar 23, 2009 03:47 PM
murderex
Feb 27, 2008 12:26 PM
