car sounds like a diesel
Old Mar 22, 2005 | 03:35 PM
abdulmo86's Avatar
Default car sounds like a diesel
i have a 1991 honda accord with only 54000 original miles and newer oem exhaust and my car sounds like a diesel when it is idling it is kind of not that loud kind of sounds like a diesel truck should i sell it what do u think is wrong i know it is not from the exhause becuase it is coming from the engine bay area
Old Mar 22, 2005 | 06:54 PM
i20ar's Avatar
Default Re: car sounds like a diesel (abdulmo86)
maybe it could be your pcv valve its about time to change it if you havent .. its really simple also
..thats not my car but yea thats where its located.. inside of it it has a ball valve thing that might be making that slight clicking noise like a diesle would... just go to autozone or whatever part store is around and ask for a pcv valve for your car... then all you do is pull it out of the valve cover and diconnect it from your tube... then replace... i suggest when you do this get a lil oil on your finger from the old one and put that and the rubber seal of the new one and also where it plugs into the tube... that would give it a better seal...
Old Mar 22, 2005 | 07:28 PM
iam7head's Avatar
check the valve clearance and timing of the motor, when was the last time you have it tuned?
your accord motor will never sounds like diesel, there's not enough compression to start the spark
Old Mar 23, 2005 | 11:34 AM
i20ar's Avatar
Default Re: car sounds like a diesel (iam7head)
i think its the clicking type sound hes talking about when he's at idol... not the sound when its running like the super pressure type sound
Old Mar 23, 2005 | 11:59 AM
ACC0RD22's Avatar
Default Re: car sounds like a diesel (14aZnS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 14aZnS &raquo;</TD></TR><TR><TD CLASS="quote">i think its the clicking type sound hes talking about when he's at idol... not the sound when its running like the super pressure type sound</TD></TR></TABLE>
have you ever heard a deisel . . . they kinda stumble . . . theres no clicking . . .
Old Mar 23, 2005 | 05:09 PM
i20ar's Avatar
Default Re: car sounds like a diesel (ACC0RD22)
yea i guess.. i jsut didnt know how to describe .. i always thought they sounded like they were full of liquid and had bearings rattling around... well thats how it sounds to me..s yea i know what they sound like tho
Old Mar 23, 2005 | 08:16 PM
as_fast_as_u's Avatar
do you by chance have an aftermarket cam in your ride...maybe the previous owner forgot he installed one and left it in for u to enjoy...that would make that sound also...yes, do adjust your valvesprings to the spec, that should quiet your engine regardless
Old Mar 24, 2005 | 01:19 PM
tubesguy's Avatar
Mine does, too, making a clatter remarkably similar to an old-style (or maybe Olds-style) passenger diesel or delivery truck diesel. The clattering occurs when I'm stopped, with my foot on the brake, and goes away when I shift to neutral. Embarasses the crap out of me in the drive-thru lane.
- Pat '90 LX auto
Old Mar 24, 2005 | 01:23 PM
philadd's Avatar
Default Re: car sounds like a diesel (tubesguy)
Like iam7head said, check timing and valve clearance.
Old Mar 24, 2005 | 06:21 PM
wragen22's Avatar
I had this same problem. I couldn't figure it out. Finally I took it to my mechanic. It ended up being the timing belt. I had to get a whole new timing belt kit. Cost me 500 bucks.
Old Mar 25, 2005 | 06:05 AM
twkdCD595's Avatar
Default Re: (wragen22)
I used to have a clicking in my old prelude... sounded like a damn sewing machine.
Got a valve adjustment but it did not help much and then a new belt tensioner... which solved most of the problem. Some of the noise I heard was the injectors and pcv clicking as well... which is normal.
pityocamptes
26
Mar 25, 2016 10:23 AM
07FG2
Honda Civic (2001 - 2005)
Mar 15, 2009 01:34 PM
jdmspoonitr
Sep 17, 2003 05:09 PM
ludenutz
Aug 20, 2003 07:30 AM
