Smell Gas & Bad Milage
My civic reaks of gas, i checked the lines, the filler neck and i changed the charcoal canister. But its still doing it???. what ever it is could b affecting my gas mileage, but im thinking that could just be the o2. If this has happened to anyone else b4 or u got any ideas id appreciate it
thanks
thanks
Well i dont think it culd be the injectors because i just put this engine in my car (blew a rod bearing on the old one
)the car i got the engine form didnt smell like gas. Even when my car had the original engine in it (the blown up one) it did the same thing? How do i go about checking the injectors anyways? Its worth a try
Thanks for the help
)the car i got the engine form didnt smell like gas. Even when my car had the original engine in it (the blown up one) it did the same thing? How do i go about checking the injectors anyways? Its worth a tryThanks for the help
start the car, open the hood and look at the intake manifold. Right around the flange if the manifold looks sorta crusty and brown and you smell gas real bad, or there are any puddles in the manifold you probably have leaky injectors.
get a stethascope and listen to the injectors they should be clicking constantly.....i jsut had this problem with my car and it was the injectors my car runs better and has so much more zip than it did before
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by travissmithoh »</TD></TR><TR><TD CLASS="quote">Are you sure you have got a hole rusted into the gas tank?</TD></TR></TABLE> Yes im sure its a new tank. <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 89hbcivicguy »</TD></TR><TR><TD CLASS="quote">get a stethascope and listen to the injectors they should be clicking constantly.....i jsut had this problem with my car and it was the injectors my car runs better and has so much more zip than it did before
</TD></TR></TABLE> Ill try this if there not clicking fast shuld i use injector cleaner or just replace the injectors?
