JDM EG coin pocket
Old Mar 22, 2005 | 02:39 PM
SubTitle's Avatar
Default JDM EG coin pocket
Modified by SubTitle at 12:09 AM 4/2/2005
Old Mar 22, 2005 | 02:44 PM
mrchaos's Avatar
Default Re: JDM EG coin pocket (SubTitle)
yes, reconnect the dimmer control....its required for most dash lighting to work.
Old Mar 22, 2005 | 02:58 PM
SubTitle's Avatar
Default Re: JDM EG coin pocket (mrchaos)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrchaos &raquo;</TD></TR><TR><TD CLASS="quote">yes, reconnect the dimmer control....its required for most dash lighting to work.</TD></TR></TABLE>
heres a pic of what was taken out, what do i have to reconnect? I disconnected the plug that was pluged in the white piece
Old Mar 22, 2005 | 03:00 PM
tsjeff's Avatar
i believe you have to connect the whole entire thing back, so that your lights will come back on.
Old Mar 22, 2005 | 03:10 PM
SubTitle's Avatar
Default Re: JDM EG coin pocket (9 3 d e l s o l)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 9 3 d e l s o l &raquo;</TD></TR><TR><TD CLASS="quote">i believe you have to connect the whole entire thing back, so that your lights will come back on.</TD></TR></TABLE>
does the back thing in the back disconnect do u know? (i dont wanna force it if it doenst and break it) well i just took out my coin pocket out and connected the dimmer back, everything works.
Old Mar 22, 2005 | 03:14 PM
mrchaos's Avatar
why do you need to take the dimmer apart?
Old Mar 22, 2005 | 03:22 PM
SubTitle's Avatar
the coin pocket replaces the whole dimmer, <TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mrchaos &raquo;</TD></TR><TR><TD CLASS="quote">why do you need to take the dimmer apart?</TD></TR></TABLE>
Old Mar 22, 2005 | 03:27 PM
BolivianFuego's Avatar
I personally just pryed out that little box under the dimmer switch and pulled the harness down to connect it in that hole. I never use the dimmer switch so i shoved it in there and closed up the hole with cover.
Personally i love that little thing. Its perfect for my garage door opener.
Old Mar 22, 2005 | 03:30 PM
Targa250R's Avatar
be professional
Default Re: JDM EG coin pocket (BolivianFuego)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BolivianFuego &raquo;</TD></TR><TR><TD CLASS="quote">I personally just pryed out that little box under the dimmer switch and pulled the harness down to connect it in that hole. I never use the dimmer switch so i shoved it in there and closed up the hole with cover. </TD></TR></TABLE>
This is what I would do; just tuck it back into the dash. Similar to what you have to do to retain factory keyless entry in a '96-98 Civic EX with an aftermarket head unit . . .
Old Mar 22, 2005 | 03:49 PM
enigma94's Avatar
Default Re: JDM EG coin pocket (Targa250R)
pull it out of the center section and do as was already stated. plug it in and push it back behind the dash and put the civer back over it.
Old Mar 22, 2005 | 03:56 PM
SubTitle's Avatar
Default Re: JDM EG coin pocket (enigma94)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by enigma94 &raquo;</TD></TR><TR><TD CLASS="quote">pull it out of the center section and do as was already stated. plug it in and push it back behind the dash and put the civer back over it.</TD></TR></TABLE>
ok coo, do i just pull the back section or all of it? i feel like imma break it
Old Mar 22, 2005 | 03:58 PM
LOL. Do you have a baby screwdriver as i like to call it? Pry that little box out with one and plug in the dimmer shove it in and put the cover back on lol.
System-7
10
Mar 28, 2007 09:36 AM
GRANT!
Jan 16, 2007 06:36 PM
gerbcrx
Dec 13, 2006 02:01 PM
SOL Food
Jun 2, 2006 08:39 AM
Demon_Dub
Sep 8, 2004 02:08 PM
